Midi, output already being used????
Hello, I installed pro tools on a new Mac and cant getto record Midi nor on instr nor in midi track. I configured everything as it was in older Mac, set busses, istalled Xpand, I see the column is rising when I play and I hear the notes, but when I record the tracks are blank they dont show the notes, when I try to choose my midi instrument in inserts it says that h/w insert can not be used because its allready being used???? also when i put xpand the colum is not rising when playing keys on the keyboard anymore too. Please help, I spend allready more than few hours trying to figure out and fix this. Id be very grateful, thank you!
Re: Midi, output already being used????
i believe Xpand can only be used as INSTRUMENt track NOT midi track
you can use aditional midi tracks if you are using "multitimbral" |
I use it on instrumental track, I dont know it confusing, im new to pro tools. I have xpand on instumental tracks, when i try to use i/o on instrumental from my keyboard it says channel allready being used.
also im trying to record drum pattern to pt instrumental track but all I get is midi notes how can i record actual drum beat that i have in my keyboard??? it should be possible? thanks.
Single MIDI Track Output to Multiple MIDI Channels? | jb_trm | Pro Tools 9 | 2 | 07-11-2014 09:09 AM |
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
No MIDI output in PT 9.02 | emmen | Windows | 11 | 04-23-2011 06:31 PM |
MIDI Output Problem - Assigning MIDI Patch Names | pancake1975 | MIDI | 8 | 05-29-2006 03:25 PM |
2 MIDI Input Tracks Output to Same MIDI Channel | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-05-2005 03:20 PM |
