Voices versus Stereo tracks
I have Pro Tools LE, Windows XP, MBox 2, Pentium IV processor, 1Gigabyte of RAM, and 160 Gigabyte harddrive.
Here is the situation. In ProTools LE I have recorded 15 audio tracks and I also inserted a clck mono track which gives me 16 tracks. When I insert track 17 a message pops up that says "There are more active audio tracks than available voices. As a result, one or more audio tracks will not play." So... track 17 will not record or play. Then I looked in the Protools reference guide and it says that I am allowed only 16 stereo tracks maximum, but 128 voiceable tracks maximum. What is the difference between a voiceable track and a track? And is it possible for me to record and play(play simultaneously) more than 16 tracks in Protools LE? |
Re: Voices versus Stereo tracks
So all your audio tracks are stereo......why? What is on all those tracks that makes you believe they all need to be stereo? It is a common misconception among those that are new to recording, that audio must be recorded to a stereo track to be used in a stereo mix and that is simply not true. Stereo refers to the output so a vocal, bass guitar, bass drum, etc, being a mono signal, would be recorded to a mono track and then PANNED within the stereo field. You would use a stereo audio track for recording a stereo keyboard or drum machine. In any case, by disabling voices(audio tracks) you can continue to add more audio tracks but you can only listen to 32 voices at a time(a stereo audio track= 2 voices). A common workaround is to buss similar things to a new comp track(like when I bussed 14 BGV tracks to a stereo track and then disabled the original 14 tracks). If you upgrade to PT8, you will be able to run 48 tracks(mono OR stereo).
Wow.
Older versions of Pro Tools had a limitation on how many active/audible voices; 32. Since stereo tracks are 2 voices, that means that limitation for stereo tracks is 16. Pro Tools allows you to have up to 128 voices recorded, but only 32 of them can be active (playing back audio through the outputs) at one time. I'm assuming you are not using the current version of the software (8.0) as it has eliminated this restriction, and allows you to use 48 tracks, no matter if they are mono or stereo. Quote:
I would also like to ask; why are you using stereo tracks? Are you recording stereo instruments? Like Keyboards?
I have PT LE 7.4 |
Honestly, using the click plugin on an aux track is the recommended way to use the click plugin, and I've done it in every single session since the click plugin was introduced. If you are using a mono source (such as vocals... ONE microphone = mono), center panning is equal in both sides of the stereo field. (this is audio 101 here...). If you're using stereo tracks for mono sources, how are you assigning the inputs? How are you recording two voices (stereo) when only one is present (one mic = mono voice)?
Let us not be a dick to this guy. He came on asking for help, like he was invited to. When some one lacks knowledge, they don't have a very good idea of where they can receive what they lack.
Pro tools is a very difficult system to learn. I know, I have been at it for 7 years and there are still aspects that I don't understand. |
Hello,
You should get someone to help you understand signal routing. You have many options for routing a mono signal to your mbox. Try using a send or a bus from your mixer to your mbox. In most cases you won't be recording stereo unless it's keyboards, drum overheads, the occasional stereo guitar rig or some room mics. Pretty much everything else will be mono. You should do some reading or get some help from an experienced engineer. There are some basic audio principles that are you need to learn to get the most from your equipment as well as you'll enjoy the process even more. Good Luck! Alex |
Check out your local Barnes and Noble or other bookstore and grab a book on recording techniques to get you started(and don't feel bad about not knowing stuff as I have been in the pro audio biz for 25 years and I am still learning, so don't take offense at the "audio 101" comment). Once you get some basic understanding, things will come easier. The next step should be watching every video you can get your hands on, from Secrets of the Pros DVD's, DigiTV(free) and even search youtube for "protools" (without the quotes) as there is a lot of stuff out there.
MIDI Tracks Versus Instrument Tracks. VERY Confused. | Rick540 | MIDI | 8 | 12-04-2008 11:04 AM |
Stereo versus Mono Question | Elton Hyland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-10-2007 01:24 PM |
mono versus stereo delay uses | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-15-2007 06:38 AM |
Stereo versus Mono - something I found and liked | IntelDoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-06-2005 07:52 AM |
Stereo Voices - Please ! | Count Zero | Pro Tools TDM Systems (Mac) | 1 | 07-13-2000 01:31 AM |
