Re: .........MATT P
Allen Allen |
Re: .........MATT P
Hey Joel,
great to see you got it going. Yes you need to Flash the BIOS. DFI DTR BIOS This should also lower the temps (common misreporting on all NF3 Boards.) The V-core, the multiplier, and RAM timings we will get to once you get it flashed I also found what other chips to cool to help make it more stable. None of my Temps are over 40C under the heaviest load and that is at 2750MHz at V-core of 1.78V. Will get to that later. if want to, also. I feel we can get 2600MHz out of that system with what you got stable on AIR.
"To Record Music Is All That Really Matter's!" "When Not Dealing with the Darkside!" Yoda (HOBO MASTER)"I'm Back from the NORTH POLE!" |
Re: .........MATT P
Matt,
Are you finding that the overclock potential of the mobile 3400+ is lower than the desktop 3400+? Seems like the mobile performance is better than the desktop at normal speeds. Is this consistent with what others are finding or is it just because it is running cooler with normal air cooling? With PTLE we are seeing about a 10% difference between the two processors so far at normal speeds and same cooling and motherboards. Allen |
Re: .........MATT P
FLASHED and Reformatted for posterity. Now what Matt? Looking forward to your reply! ~ J
Joel DuBay Ready Acoustics LLC Bass Traps and Acoustic Panels www.readyacoustics.com |
Re: .........MATT P
Hey Allen,
No I'm basing this off the type of cooling one is using, the type of memory, the power supply, and the fact that 3400+desktop has max multiplier of 12 and the 3400+DTR has a max multiplier of 11. Also I won't encourage someone to run a BIOS that I Modded and lose their warranty. Also I won't ask someone to push a system to the edge without understanding that it can all go up in smoke that quick. Yes in my setup the DTR would OC' just as high or higher depends on the ability of the chip. I probably could get at least another 2-4 tracks on DaveC, but like I said I'm Waiting for Venice and San Diego to come out and drop in price for the next barn burner. Hope this explains everything Matt
#16
Re: .........MATT P
Hey Matt,
I will NOT hold you responsible for anything that may or may not happen to my computer when helping me. In fact, if there was a problem, I probably wouldn't say anything at all. Okay, I am flashed and ready. My CPU temps are way down to about 32C. I have my CPU voltage set to 1.4. I have made no other adjustments. So, naturally, my CPU says it is at 800Mhz. What is the safest way to bump that up brother?! I am all eyes at this point! Thank you Matt and Allen! ~ J
#17
Re: .........MATT P
Hey Joel,
First I need to know where everything is reading and set by default. Then I can tell you what to change to get it running at its best config. First off set the CPU multiplier to 11 and leave the Voltages stock. These are found under the Genie BIOS Setting. The CPU voltage is controlled by the CPU VID control and the CPU VID Special control. I also need to know if the RAM is POSTing at 333 or 400. Also what are the timings this shows during the POST? To see the POST you need to disable: The Full screen Logo and the EPA LOGO under Advanced BIOS features. Also what are your where are your Temps at? Matt
#18
Re: .........MATT P
Joel,
I doubt it is running at 800mhz. That is probably the FSB speed. Did you try the Sisoft Sandra testing yet? That should give you the correct speed it is running at and smell out anything that may be a problem here. So far it looks good. Did you have any problems mounting the Zalman fan on that motherboard? Allen |
#19
Re: .........MATT P
Ok, I'm going to stand back and watch Matt work some magic here.
Allen |
#20
Re: .........MATT P
Okay, I set the CPU multiplyer to 11. However, I had the core voltage already set to 1.4 shall I bring it back to: .950? Speed: 2.21GH RAM is posting at 400 (C3) I did not catch the timing this time even though I have the large and small LanParty logos disabled. CPU is at 25C according to Sandra, but they were at about 37 in the bios just before I ran Sandra. System Bios version 6.00 PG I am not sure if I got you everything you need or not.....let me know. I will try to see the timings when I reboot in a second...
Help me Matt Stutter - You're my only hope | Ivory Tower | Post - Surround - Video | 5 | 03-03-2009 09:37 PM |
is mr. Matt P in the house???? | guitardom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-23-2007 08:30 PM |
MATT P | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-07-2007 09:48 PM |
MATT P | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-06-2007 07:10 AM |
...MATT P vs. Allenstein | who | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-14-2005 02:50 PM |
