Re: Bouncing multi tracks (individually?) at the same time
PT has Export as AAF or OMF.
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com |
No need, just select the desired format in the export window and PT should (and I say should because 32bit ip seems to be broken) convert everything on export.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
You can bounce busses too, not only outputs.
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
1) Create a send on each track, each to a new audio track. You can name all those new tracks with the prefix STEM so you can identify them easily later. 2) Record on all of those new tracks. This way you will have a bounce of each track including any plugin processing. 3) You can find the created files in your audio folder. If you need them in a different sample rate, then go to step 4. 4) Select the stem tracks. Go to the File menu and export selected tracks as new session. Set the desired sample rate and bit depth in your new session. Then go to the audio folder of that new session to find your files. This may sound a little complex, but you can do all of this in less than 10 minutes. HTH
If you need the effects printed you just Commit the tracks instead of consolidate, and select the committed regions. You can access that same "export clips as files" from the drop-down menu at the top of the clips panel (the panel you expand on the right-hand side of the edit window.) |
"Export clips as files" will do the conversion he asked for too.
The export clips as files dialogue offers conversion of sample rate and bit depth.
It's not missing. You just have to know how to do it.
That's what I was trying to say in post #3, easiest way I've found
Bouncing multi-channel audio | altoidboy | Pro Tools 11 | 14 | 04-22-2014 12:46 AM |
Time remaining stuck while bouncing! It takes twice the time | Retinal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-10-2008 08:33 AM |
Bouncing tracks - taking a long time | Gonkboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-26-2007 03:02 AM |
Multi-channel vs Multi-mono plugs on 5.1 tracks | geitz | Post - Surround - Video | 0 | 06-08-2007 09:06 AM |
Multi-channel vs Multi-mono plugs on 5.1 tracks | geitz | Pro Tools TDM Systems (Mac) | 0 | 06-07-2007 02:54 PM |
