Pro Tools 2018.12 and macOS 10.12.6?
Considering moving to Pro Tools 2018.12 to run on macOS 10.12.6. Anyone know of any success with this configuration, or warnings?
You should always refer to the Avid compatibility doc. 10.12.6 is officially supported and has been for a while. macOS 10.12.6 is my preferred version to run, though 10.13.6 is supported as well with 2018.12. http://avid.force.com/pkb/articles/c...m-Requirements
Sent from my iPhone using Tapatalk Pro |
Re: Pro Tools 2018.12 and macOS 10.12.6?
10.12.6 is a great version.
I stuck to it for as long as possible. Last month I had to move to 10.13.6 due to some Apple software. Not liking Pro Tools as much now. I would revert if I could. 10.12.6 was golden.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I would avoid 2018.12 because of the slow playlist problem (I was running it on 10.12.6) and reverted back to 2018.10. Running stable here.
James Welch Recording Engineer | Producer Masterlink Productions Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire) macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24 |
Thanks for the several responses - all good info to go on from here.
There was no problem running on the cheesegrater even though it doesn't have the i5/i7 the charts says is needed? I have a 3.46 GHz hex core 2012 5,1 and contemplating going with PT2018 on said machine.
No serious problems here. But do read my other posts about laggy GUI.
And no GUI problem either. Also, you might want to check your info http://avid.force.com/pkb/articles/c...m-Requirements
I'm thinking with my tax return due soon about moving on up the ladder a bit (but not HD though). |
Core i5/i7 are considered below Xeons found in the Mac Pros (whether cheese grater or trashcan). Not conflicting for that reason. They are just stating the minimums up top.
ProTools 2018.4 Ultimate and macOS Mojave | BillDog793 | Pro Tools 2018 | 121 | 03-07-2019 04:37 AM |
PT 2018.7 on MacOS 10.14 Mojave works for me | veinticinco | Pro Tools 2018 | 38 | 12-09-2018 07:35 AM |
macOS 10.13.6 with 2018.4 | SigFriedChicken | macOS | 8 | 07-26-2018 02:39 AM |
Weird UI glitches in 2018.3 on macOS 10.13.3 | Chingy | Pro Tools 2018 | 6 | 04-06-2018 05:17 AM |
Sluggish Zoom in/out + scrub issues 2018.1 (MacOS 10.13.3) | Hrmonik | Pro Tools 2018 | 0 | 01-28-2018 10:35 AM |
