Old 02-12-2019, 03:00 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Using Waves StudioRack in Pro Tools
when I signed up with Waves (well, brought a few plugs) they offered StudioRack for free in my account which I guess is standard for all. I haven't downloaded it yet thinking loading that up all over the place would just increase CPU load. Why wouldn't you just create track presets? what is the benefits of StudioRack that track presets cant cover apart from extra eye candy? I mean it does look good. but in all reality all it really does is turn PT inserts into thumbnails which you can click on, just like I can click through the inserts in PT in the same way and still see the plug in PT's plug window. Or does it offer other things of benifit.
Is it better to use StudioRack with some external processing like SoundGrid Mobile Server or similar.
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 02-12-2019, 03:02 PM
amagras amagras is offline
Default Re: Using Waves StudioRack in Pro Tools
I don't use it too much so I'm not sure of other features but you can insert 8 plugins in one PT insert slot.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 02-12-2019, 04:27 PM
xrekcor's Avatar
Thanks for your reply....
Do you use or need to use external processing?
Rob
Old 02-12-2019, 04:30 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
^^^This. More "inserts" as it were. I have set ups saved for various things which now that PT has track saves it's less needed. But i have stuff like one "rack" for things like BV , bass, etc and i have some "racks" that are just comps or just eq's so i can click through to get different flavors to find what works best for a particular track which is easier than setting up a bunch of inserts... Of course it only works for Wave stuff. But if you have a waves effects "chain" that you use regularly it can simplify.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 02-12-2019, 05:40 PM
xrekcor's Avatar
you guys haven't mentioned anything about external processing so I'm guessing you are using it without... yeah?
thanks for you replies..
Rob
Old 02-12-2019, 06:22 PM
See my signature.
amagrasmusic.com
Old 02-12-2019, 06:29 PM
Sardi Sardi is offline
You can also link multiple parameters of different plugins to one knob/dial. So you could automate one dial that is automating multiple parameters.
Think linking in/out controls. Sweeping cutoff and resonance at the same time. Loads of possibilities for creative use.
Old 02-12-2019, 06:52 PM
I didn't know that (haven't touched the manual yet), thx. Cool if they have put a wet/dry knob somewhere
amagrasmusic.com
Old 02-12-2019, 07:23 PM
xrekcor's Avatar
See my signature.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
seems like a lot of of stuff just to external process.....
Rob
Old 02-12-2019, 09:26 PM
64GTOBOY's Avatar
No external, all ITB for waves plugins. I have external compressors that I use mostly tracking and mixdown but not usually when mixing.
HTML code is On
Waves StudioRack Sergius AAX Plug-ins 1 10-17-2018 04:23 AM
Waves Studiorack Righty27 AAX Plug-ins 375 02-19-2015 01:23 AM
Question about Studiorack Native mesaone AAX Plug-ins 2 10-01-2014 08:44 AM
Waves StudioRack - example of good plugin chain presets implementation in Pro Tools jacko AAX Plug-ins 22 07-28-2014 10:32 AM
Waves StudioRack Native plugin rjmurry Pro Tools 11 2 07-23-2014 02:22 PM
