Dither plugin necessary in Pr Tools 11?
Hello!
Is it still necessary to use a Dither plugin in the Master Bus when bouncing to disk with Pro Tools 11, like we did with previous versions? |
Re: Dither plugin necessary in Pr Tools 11?
Dithering is ALWAYS necessary when truncating from 24 to 16 bit. It has nothing to do with a specific version of PT.
Who told you this and why? Sent from my iPhone using Tapatalk |
Thank you for your reply, Sardi. I was studying a mixing course, but it was based on Pro Tools 9. In the course, they instructed us to always add a Dither plugin in the Master Bus before bouncing to disk. Since Pro Tools 11 now has offline bouncing, I thought the newer versions might already have added Dithering during the bounce, instead of having to add it manually as a plugin.
In any/all versions of PT, adding dither as the last plugin is only required if the session is 24 bit, but you are bouncing to 16 bit(as you might for creating a file to burn onto an audio CD).
If your session is 24 bit and want to EXPORT a file to 16 bit, the PT adds dither automatically. This is handy if you(as many do) record your final mix to a stereo track in the session(which will be at the same sample rate and bit depth of the session) and then export(not the same as Bounce to Disk, but works fine for those that prefer this method). If you are sending your mixes out to be mastered, keep them at the session's sample rate and bit depth and let the mastering engineer take care of it. My preference is to work at 24 bit/48K. If I am "self-mastering" a single song, then dither is among the processes I use on the master track(always the last process). BUT, if I am doing a collection of several songs, I will bounce all at 24/48>Import the finals into a new "mastering" session and process each song(so I can compare and make sure levels and tonality match). Then I use Track Commit to make the final masters(without dither) and Export Clips(and let PT do its automatic dithering)
Thank you, albee1952. I appreciate your help!
A dither plugin between two, to stop CPU Spikes | Intransit | Pro Tools 11 | 4 | 10-30-2015 09:51 AM |
Dither ... placement of the dither plugin. | tpthai2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-12-2007 07:20 AM |
dither plugin explained | probe dms | Pro Tools TDM Systems (Mac) | 3 | 03-26-2006 01:15 PM |
Maxim / dither plugin on master fader? | voltech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-28-2003 03:45 AM |
Waves L1 plugin instead of Digi dither? | EjA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-29-2003 12:44 AM |
