Old 01-23-2019, 09:23 AM
John J. John J. is offline
Default C24 Mic Inputs 1-8 D25 Need Help!
Hey Guys,
Needed to buy a D25 mic inputs 1-8 cable for my C24. Female mic D25 cable for 8 mic inputs. The Avid C24 guide doesn't give any info about using this D25 input as far as routing, how-to. I plug the D25 into the back of the C24 "mic in 1-8", powered the C24 off/on, opened Protools 10, created a test session with 8 mono audio tracks.
The D25 I purchased from a very reputable audio company, they assured me the D25 cable I was purchasing used Tascam protocol which they said is what the Avid C24 uses. I expected to plug in the D25 into the C24, hook up a dynamic mic to female input #1 of the cable, turn up mic gain #1 on C24 and get a mic signal. I get nothing.
Can someone here please tell me what I'm missing/doing wrong? I need to get the C24 mic inputs 1-8 working via this D25 cable as soon as possible, thanks in advance!
MacPro 2.66 8 core • 24G ram • Lotsa Terrabytes
OSX 10.8.4 • MBP Core i7
C|24 • PT 10/11 HD • Reason 6
www.icedrum.com
Old 01-23-2019, 11:16 AM
henningaround henningaround is offline
Default Re: C24 Mic Inputs 1-8 D25 Need Help!
Did you wire the line outs of the C24 to your audio interface? It's been a while since I used a ç24 and I don't know if there is a way to see the mic inputs on the meter bridge.
Old 01-23-2019, 11:41 AM
Top Jimmy's Avatar
Tascam format actually only applies to AES digital on a DB25 connector, but it's wired the same as analog so your cable should be all good.
The previous poster mentioned that you need to have another DB25 cable coming out of the C24 connecting to an audio interface. That's correct as the C24 only has the preamps. Your sig doesn't mention your interface(s) but if you have a 192, you just need to connect up to the analog line ins.
James Cadwallader
Old 01-23-2019, 04:02 PM
Thanks James.
My set-up is ProTools working with HD native card (Mac) connected to my Apogee Symphony I/O. I have the C24 1-8 outputs connected via D25 cable into the Symphony D25 inputs. What I can't figure out is why the D25 cable with 8 female XLRs connected to the C24 1-8 inputs is not working when I connect a microphone and attempt to set an input level using mic input knobs on the C24?
www.icedrum.com
Old 01-23-2019, 04:55 PM
Top Jimmy's Avatar
Is the input cable plugged into Mic In 1-8 and not Line/DI in 1-8? Is the preamp set to mic in? Does the clip indicator illuminate if you crank the gain too high with signal present? Can you get signal if you plug into the 1/4" DI jack on channel 1 and choose the DI input on the preamp?
James Cadwallader
HDX 192 "-10" analog inputs - ok for use 'alternate +4 inputs ? sbarncar Pro Tools HDX & HD Native Systems (Mac) 22 12-09-2018 01:00 AM
Control 24 inputs or Digi 192 inputs?? Al Rayder ProControl, Control|24, Command|8 6 06-22-2018 05:04 PM
Using Eleven Rack inputs like POD X3 inputs dayslypper Eleven Rack 1 10-09-2010 09:15 PM
Analog inputs 5-8 not seen as inputs on tracks sitarartist Pro Tools M-Powered (Mac) 4 09-16-2010 08:24 AM
How do I utilize the Line inputs when all my XLR inputs are being used? 007audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2009 08:21 PM
