Plugin Alliance Question Bx master deck
Do you use a limiter after the bx-Master deck or is it limiter. I understand it is for mastering but it is the final plugin except may a dither or are you suppose to use it as a compressor and then use a limiter
Wow am I groovy or what |
Re: Plugin Alliance Question Bx master deck
It’s an all in one with final limiting stage Chris
It's not a brick wall, though, right? IIRC, one can still hit the ceiling if not careful. Then again, I can't say that I've heard it clip.
Thanks for the reply , One more thing ,, Looks like Plug in Alliance released a new plug in called spl IRON. Wasnt sure iftha was similar to the Master deck. In one of the video a guy has a waves L 1 plug in after the Iron plug in
I think these are two different things. The desk has a compressor working behind the scenes as part of it's processing. The Iron is a compressor. (might be more, but I have not looked at it much at all.)
I do use Pro L2 after it but just for dither.
Mac Studio M1 Max Apollo X6 MacOS Ventura |
even thou you use it for dither would that also brick wall at where the plug in would be set?
Yes, pretty much, there isn't any limiting as far as pro l2 goes. That I've noticed anyway.
Question For Those Having Plugin Alliance Issues | PatriotsBiker | Pro Tools 12 | 11 | 11-09-2017 05:15 PM |
Free Distortion Plugin Available from Plugin Alliance | Seafoam_Green | AAX Plug-ins | 14 | 08-09-2016 09:41 PM |
Anyone else have issues with Plugin Alliance Rtas plugin presets? | realizment | Windows | 0 | 04-01-2015 05:04 AM |
Mega plugin deals!! Slate, plugin alliance etc | crizdee | AAX Plug-ins | 3 | 02-06-2014 11:03 AM |
Master Fader and First Plugin Question... | M2E | Pro Tools TDM Systems (Mac) | 5 | 01-01-2011 02:32 PM |
