Old 05-30-2011, 03:52 AM
pmcmurt pmcmurt is offline
Default Remote access to HD Core & Process Cards though the LAN????
Hi there!
I have a question.......
1) I have a Mac Pro (latest Snow Leopard OS X - 8 cores) and G5 (Leopard - 2 cores - ProTools installed) computers.
2) G5 has HD Cards installed. Runs great but because of 2 cores on G5, it runs out of processing power quick. Rubbish! :-(
3) Mac Pro talks to G5 though the LAN - 1Gbps (slow compared with the new Thunderbolt from Mac!)
Question.......
If I install ProTools on my MacPro, can I access the HD cards on the G5 remotely through the LAN? 96 Stereo tracks x 24bit x 96kHz equates to approximately 0.42144000 Gbits / sec which leaves approximately 0.578560000 Gbits / sec headroom! Phew! Hope I got that right
So if rates are not an issue (ok, latency might be but can maybe be a workaround?) then what is?
Can you possibly assist?
If yes, then I look forward to tapping into your experience and knowledge!
I have zero money to spend at this point in time so no comments about External Chassis config's, been through that a thousand times!
Thanks.
Phill
I look forward to your response(s).
Phill
Old 05-30-2011, 05:29 AM
the dude's Avatar
the dude the dude is offline
Default Re: Remote access to HD Core & Process Cards though the LAN????
the answer is no
the g5 can not share the TDM resources with the macpro or visa versa
you can use it as a second standalone machine both running pro tools and HD hardware then rout the audio via a digital IO between the 2 machines
the G5 will just be rack of gear ( kinda )
http://www.studio-techservices.com
าำ
studio.tech@yahoo.comm
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 06-04-2011, 12:40 AM
Awwwwhhh! That's a real shame. Hey ho!
You clearly mentioned HD Hardware. I do also have a 003 Audio Interface, if connected to the Mac Pro, would that not work?
Any work arounds?
Thanks.
Phill
Phill
Old 06-06-2011, 12:15 PM
Craig F Craig F is offline
same rules apply so, no
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 03:39 PM
Modern motherboard for original PCI HD Core and Process cards David Sandwisch Pro Tools TDM Systems (Win) 48 08-28-2011 03:19 PM
Do I Need HD2? (Process HD vs Access cards) gsilbers Pro Tools TDM Systems (Mac) 5 01-08-2010 04:39 PM
PCI-X G5 and HD core and process cards Charles Schaefer Pro Tools TDM Systems (Mac) 5 12-26-2005 03:23 PM
HD Core and process cards faulty??? Michel Pro Tools TDM Systems (Mac) 7 03-09-2002 05:59 AM
