Old 04-07-2005, 07:27 AM
·[-_-]· Richon ·[-_-]·  Richon is offline
Default I\'m Crazy....or in the Twilight Zone????
I took mi PC and:
Change the Processor from Athlon Xp3000 to 2100 and a 2600... and the cliks continued!!!
I put the Athlon XP2100 with the memorias the other PC has (a Pc of a friend who uses also the M-box with no cliks) and the cliks happened again...
and i've changed the video card...tree times, PSU 3 times, Hard Disc 5 times, etc...etc...
there isn't more to test besides configuration, but i'm sure we did it complete...
and now my PC don't work in any way i've test it!!! ... and if we don't find what is wrong with it... how would i be sure that a new Pc would work?????
This is what i have: Athlon Xp3000 Asus A7V600-X Corsair512MB DDR400 WD 80GB 7200rpm Asus9550TD and my BELOVED M-box!!!!
Powerbook 12" 1,5Ghz 1,25Gb RAM
M-Box v.1.0 "the old one"
PTLE 7.0 Tiger(10.4.6)
Ministack v2 NEWERTECH FIREWIRE+SEAGATE 320Gb
Old 04-07-2005, 10:18 AM
Default Re: I\'m Crazy....or in the Twilight Zone????
Clicks and pops are usually due to a clocking issue between digital audio devices. What is your source? Are you using a digital mixer? Are you using any digital devices in your chain? It is probably not caused by your PC. I'm sorry you went through so much trouble shooting on the PC when I think that is not the cause of your problems. This is usually the symptom of connecting two digital audio device with different sample rates (for example: 44.1KHz to 48KHz or 96KHz to 44.1KHz). Make sure both are set to the same sample rate and one is set to internal clock while the other is set to external clock.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.15.2 running Protools 2019.12.0
Old 04-07-2005, 10:44 AM
sorry to be so mad..... but I KNOW THAT!!!!
therefore... all the time i've tested the 2 PC and the M-box ......only the M-box is attached to the PC.... and only a Mic to the M-box!!!!
Old 04-07-2005, 11:16 AM
Well.. do you get clicks and pops when playing back the demo session with your clock set to INTERNAL?
Have you installed the latest MBox firmware?
Are you using the supplied USB cable?
Are you using a USB powered (or unpowered) hub?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-07-2005, 11:24 AM
The Demo plays well without any cliks..... always the clock is set to Internal
Yes the lates Firmware and the supplied USB cable...
No, i'm not using a USB powered (or unpowered) hub.... and already tested an PCI to USB 1.0 , 1.1 and another to 2.0 USB.... and the same...
Old 04-07-2005, 11:28 AM
Okay - so tell us about your microphone and the cable it's attached to... is it balanced? What model microphone? Where's the gain on your MBox set to for the preamp? Is phantom on or off?
Rail
Platinum Samples
Old 04-07-2005, 11:40 AM
It happens when the phantom is on ...condencers.... and off... dinamics
when plugin an guitar or Bass direct to the M-box...
my cables are tested.... as the cables of a friend (who has a studio with a DIGI001 who makes the same noise in my pc but no clisk in his)
This happens with every tipe of microphone: ShureSM57 ,58... Akg414.... C1000... audiotenichas...behringers... shures
Where's the gain on your MBox set to for the preamp: between 12o'clock and 2 o'clock
Old 04-07-2005, 11:49 AM
Tell us about your power supply... what brand and how many watts.
Have you tried using your MBox on another system and had success? Try using a powered hub.
Rail
Platinum Samples
Old 04-07-2005, 12:11 PM
first PSU : Thermaltake 480W 2 vents.
second: Generic 400W 2 vents.
third: Generic 350W
i've test them on 8 differnt places...
A friend's PC work great with my M-box... and he has an AthlonXp2100... 2x256MB Ram of diferent brands... only one Hard Drive... windowsXP with al the Spyware you can find on the WEB ...antivirus enabled, Office... a lot of games... ana nothing disabled on the BIOS.... AND WORKS GREAT!!!
A PCI to USB card is like a powered Hub, isn't it?
Old 04-07-2005, 12:16 PM
spkguitar's Avatar
You have XP Service Pack 1, right?
No go zone filosofem Virtual Instruments 3 05-19-2007 06:46 PM
twilight zone Steve MacMillan Pro Tools TDM Systems (Mac) 3 01-16-2004 04:25 PM
The DIGIlight Zone BesnikB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-17-2003 03:38 PM
PC crashed on me.... help!... I'm in the 'Zone' right now.... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 38 03-13-2003 11:02 PM
RED ZONE stickstome2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-02-2001 09:02 AM
