HyperTransport on AMD AThlon64??????
what is it..... should be on or off.... or maybe it doesn't matter???
Powerbook 12" 1,5Ghz 1,25Gb RAM M-Box v.1.0 "the old one" PTLE 7.0 Tiger(10.4.6) Ministack v2 NEWERTECH FIREWIRE+SEAGATE 320Gb |
Re: HyperTransport on AMD AThlon64??????
Hypertransport can't be turned off, it's the underlying bus technology behind how Athlon 64 talks to all outside devices: memory, peripherals, ports...
Completely unrelated to Intel's HyperThreading.
Quad 2.5 G5, 4.5G RAM |
ok...thanks.... just scary ...cause my f******** Pc isn't working as it should..... some cliks during recording.... and IDE drive with time lag when i record.... and i have a pretty decent PC (athlon64 2800+ 1GB RAM + MSI K8Tneo MOBO....
i have cliks when recording..... little electronic clicks... so far i've done everything to do to have a quick PC ...and it is!!!... but the clicks are always ther...sometimes only one in 4 minutes and then ... 3 in one minute.... it's really anoying... but i keep on fighting....
also... some pal told me to change the Audio recording hardrive from a 120GB SATA to a IDE 7200RPM (but with 2MB cache).... and the clicks aren't gone and now when i start recording it takes 3 to 5 seconds to start.... maybe it's the MOBO...that isn't compatible or something else... (i've learned a lot to make this pc work with protools...but i think they want me to be a super geek to make this work)..
List your system specs, hardware, sp1 or sp2, etc, What buffer are recording?
(Athlon64 2800+ ; 1GB (2 x 512MB) kingston DDR400 3200 RAM; AsusRadeon9200 128Mb video card;Microstar (MSI) K8T NEO - Fis2R ; 1 X Western Digital 120GB Sata HD (OS) ; 1 X Western Digital IDE (7200rpm 2 MB cache) (Audio recording)
XP Professional SP1 H/W 85% Buffer 512 (it happens on every buffer size) M-box (PTLE 6.4)
It is important to install Motherboard drivers from MSI, this fixed a lot of my initial problems with my 3500+..
Have you done this?
Ill suffer winter alone; ten thousand miles from home... |
I know i instaled drivers.... but... are you talking about something special drivers???
(i've checked every hardware driver just in case..and everything is ok and perfectly running)
For the SATA drives, there is special SW Drivers on the MSI boards.
Which motherboard are you using?
Hypertransport sames as Hyperthreading? Asus A8V | coryc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-10-2005 02:06 PM |
HD an Athlon64 | s0nguy | Pro Tools TDM Systems (Win) | 5 | 07-26-2004 08:16 PM |
Hypertransport vs. Hyperthreading | Jake001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-30-2004 02:18 PM |
Athlon64 | Slowfizz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-09-2004 01:28 AM |
P4 Prescott vs. Athlon64 | [KGB] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-15-2004 08:31 PM |
