Old 01-03-2005, 01:06 PM
·[-_-]· Richon ·[-_-]·  Richon is offline
Default K8V SE Deluxe : Promise or Via for SATA Hardrives?
exactly... just the question..... i've tried both and see no diference.....although it should be some, isn't it???
and, why when conected a 120GB SATA Western Digital to the Promise controler as a IDE mode 6...when formating take a lot more than usual....(you know SATA drive get very fast formated)
Powerbook 12" 1,5Ghz 1,25Gb RAM
M-Box v.1.0 "the old one"
PTLE 7.0 Tiger(10.4.6)
Ministack v2 NEWERTECH FIREWIRE+SEAGATE 320Gb
Old 01-04-2005, 05:45 AM
Default Re: K8V SE Deluxe : Promise or Via for SATA Hardrives?
so , there is no big difference or no difference at all if i conect the hard-drive to the Promise or Via controler?????
but i guess because one is on board and the other on the processor there must be a little difference....more stable...faster... etc...???
Old 01-04-2005, 06:58 AM
Riad Riad is offline
If I understand your question, you should see no real difference in connecting the SATA drive directly to your motherboard or a dedicated controller card.
Make sure you disable RAID in the mobo BIOS.
I have not heard that SATA drives format quicker than IDE drives, if you have the 10K Raptor drives then they may format slightly faster because they are faster drives, but nothing very noticable.
Rob
www.carvelstudios.com
Old 01-04-2005, 09:26 AM
Straatocastoer Straatocastoer is offline
I built my computer on the K8V Deluxe, and while in process I called Asus to ask them what the difference would be. I was advised by Asus to use the Promise controller for a more stable environment. They really didn't have much else to say about the subject really. I have my SATA drives connected to the Promise controller and have had a very stable system.
-Stan-
CrossFire Studios
ASUS K8V SE Deluxe & SATA Problem... RCAinTN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-11-2007 10:02 AM
A8V- Deluxe SATA dramas the purple void 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-02-2005 12:28 PM
Asus A8V Deluxe motherboard SATA setup jimbouy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-19-2005 10:12 AM
K8V SE DELUXE/ WINXP CAN'T FIND SATA HD'S powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-07-2005 02:07 AM
Asus K8V Models- K8V- K8V Deluxe - K8V deluxe SE zepp9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-04-2004 09:34 AM
