Old 12-10-2018, 03:09 PM
subwoof subwoof is offline
Default Omni headphone mix out rear port
Anyone sending a headphone cue mix out the rear TRS ports of an Omni instead of the front HP jack? If so, how have you set that up? Thank you in advance.
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 12-10-2018, 07:02 PM
Default Re: Omni headphone mix out rear port
What is the end goal here? Its simple enough to send a headphone mix out any available outputs(mono or stereo) and route to a headphone amp. I run 6 stereo headphone mixes out of my interfaces(2x HD IO and 2x 192 IO). The only caveat is, the Avid boxes have all balanced outputs, and if they feed an UNbalanced input, you MUST NOT ground the cold side of the signal. Since the AUX inputs of my headphone amp(ART HeadPro 6) are unbalanced, I made a special DB25 breakout to maintain the correct wiring(if you don't, it can damage the interface(OMNI, HD IO and 192 IO are all the same on this IIRC, but do read the manual for the OMNI, in case Avid did something different on that unit)
Old 12-11-2018, 05:01 PM
LDS LDS is offline
It is a little restrictive, but it should be possible. The TRS outputs on the back can only ever mirror outputs 1&2 or outputs 7&8. You can configure it in the last tab of the 'hardware' menu in Pro Tools, or via the setup buttons and 'TRSOUT' on the front panel of the Omni. You would also need to change the output routing in the I/O menu of Pro Tools. I think the Cue 1-2 default to output 9&10, but you can change it to output 7&8 if it is free.
You also need to make sure that none of your monitoring configuration is assigned to 7&8. It won't be available to route to if it is! I would be inclined to think that routing out the DB25 output 7&8 would be a little more straight forward.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 12-12-2018, 10:59 AM
SDDP SDDP is offline
When recording VO/ADR, I use the front headphones for my own headphones and the two rear TRS: one for talent HP and the other for the director HP.
-Mac Pro 7,1 16core 3.2GHz 96GB
-OSX 12.7.2
-PTHDN 2023.12 Ultimate
-HD Omni
-BM Intensity Pro
-Waves Mercury+SSL4000 Collection+Abbey Roads
-iZotope RX10 Advanced
-iZotope Post Production Suite 6
-iZotope Music Production Suite 5
-HALO UP/DOWN MIX
-ANYMIX
-Delonghi Perfecta ESAM 5600.S
HD Native Thunderbolt headphone port JCBigler Pro Tools HDX & HD Native Systems (Mac) 11 02-05-2016 09:29 AM
Eleven Rack headphone port versus MBOX and other interface headphone ports World Spirit Eleven Rack 3 02-12-2012 11:34 PM
G5 rear FW port not working with Digi002 kennyT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-10-2006 04:46 PM
DUC Quick Poll: G5 Rear FW Port/ 002 Rob Ruce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 27 05-14-2005 10:52 AM
Adat sync/rear serial port bonneybear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-20-2001 08:29 AM
