Old 06-06-2020, 04:38 AM
rickmusik rickmusik is offline
Default Mixed up channels MCcontrol, MCmix
Hi .. I have a Euphonix Mc Control and two Avid Artist Mix units.
They used to line up with Logic channels logically but now seem to mix the channels up. For instance Channel 1 appears on channel 8 of the MC Mix and Channel two in Logic appears as channel 5 of the second MC Mix. Also when moving around channels in Logic the Eucon units don't reset. It all used to work fine ... any ideas? Thanks Rick.
Old 06-07-2020, 10:09 AM
EddieJones's Avatar
Default Re: Mixed up channels MCcontrol, MCmix
What version are you on of EuControl
Old 06-07-2020, 01:53 PM
turban turban is offline
i'm also experiencing issues since i've updated my Logic Pro X to version 10.5.
for example: Faders on my MC Control don't reset after quiting Logic or just closing session. They reset as soon as i open a new one, but until that, faders and on screen info are up from the last session.
I've updated Eucon software to the latest version (20.5.) but nothing changed
Other DAW's that i'm using my MC Control with (Ableton & Audition) are closing faders normally, just like Logic did before update.
Old 06-29-2020, 04:56 AM
Channels are still mixed up and I have the latest software EUCon from the Artist site that will not be maintained in the future. Apart from the transport on the artist the system is totally useless with Logic.
Old 06-29-2020, 01:39 PM
EddieJones's Avatar
Please update to 20.6.0 or 20.6.1(coming tomorrow) and report back
Old 06-30-2020, 06:25 PM
MoPro's Avatar
MoPro MoPro is offline
Check the EuControl software, on the add surfaces page... make sure your surfaces are in the proper order from top to bottom, where ch1 is the top, and your channels get higher as you progress to the bottom.
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 07-03-2020, 11:02 AM
Hi again I've just updated to 20.6.1. and updated the firmware to all three units but the tracks are still totally mixed up. I have the 2 Artist mixes and the Eu Control in the right order but the tracks are mixing between units! Totally confusing! Channels do get higher within the EU control software so that looks ok.
Old 07-03-2020, 11:18 AM
...It seems that the Logic tracks are random on the artist mix! The transport works and the track faders change the I click on another track in Logic ... sometimes... I can't see a pattern to it.
Old 07-04-2020, 06:16 AM
Hey Rick, i only have one Artist Control unit so i cannot really solve your problem, but i'm wondering what happens to your faders when you quit Logic?
Do they remain in the position from the last session?
Old 07-04-2020, 06:28 AM
Hi Turban.. On quitting Logic all the faders return to zero and the screen resets to oblong blanks. It's strange...the faders are connected to tracks in logic and respond but are just totally mixed up. The transport also works ok on the MC Control. I've had to revert to using the mouse as the tracks are so mixed that it takes ages to find the track that you are looking for. It has been working fine for a few years up until a couple of months ago I stayed on OSX 10.4.6 for safety and have updated both firmware and EuControl software. Don't know if I'll eventually have to find another solution.. it's a pity because this setup seemed the best solution when I looked at what is around.
User settings for MCControl FlorianE Artist Series 0 11-20-2014 12:25 PM
SE 8 channels mixed up bandmfp macOS 0 05-17-2013 07:36 PM
McControl stop following selected track TuckerMix Artist Series 0 04-18-2011 05:11 PM
PT9 and MCControl v1? fsb1 Artist Series 7 11-11-2010 12:49 PM
Euphonix Support-Flickering Display on MCControl chris perry Artist Series 2 09-15-2010 02:14 PM
