Please Help! Click track shows signal but no sound.
Windows 7 + PT 10
A click track was created with the default click software plug-in. As an option I have also created a click track using TL Metro. Click is enabled Metronome icon is on (blue) The signal meter shows the click but no sound either for playback or record. I CAN hear sound on a MIDI track. Only the click track does not work. I TRIED with no results: 1. Re-starting 2. Deleting and creating a new click track. 3. Inserting it on the Master Track 4. TL Metro also has no sound You help is really appreciated. Thanks!!! |
Re: Please Help! Click track shows signal but no sound.
Is 'Main output 1-2' selected on the click track channel strip output selector?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Yes, it is. This is at a school where there are 4 computers with the same set up. The other 3 are working ok. I am just puzzled at this one. As I mentioned, the MIDI Tracks are working. Have you re-installed the program? Does this sound like a glitch? Please let me know if something else comes to mind. THANKS! |
And you are absolutely sure the click plugin is not in bypass mode, an awfully common/easy mistake to make.
Also try delete the click track and creating again with Track>Create Click Track. Try to create a entirely new blank session, not from template and add a click track with Track>Create Click Track. What is setup>Click/Countoff set to? Yes if the meters move, that is not the issue. But just set it on for everything. What is the click plugin volumes set to? You could try default the IO, but I doubt that will help. What happens if you move the working session from a good system to the one not working? Yes I know you should not have to/this is not complex but try. Are the PT installs/versions identical? Are the click plugins you are absolutely using identical (file sizes/versions?). Screenshots of the edit and mix window and click plugin window showing as much info/detail as you can may help. Darryl |
After making what darryl said please tell what audio interface youre using....
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Can you post a screen shot of the MIX window? Do you have any Arturia plugins running on this computer?
Sergio |
Are all these computers absolutely identical? How do you know? are the disk drives imaged off a common image etc? Can you just reimage this one? Does the PC with problem play other audio sounds though Pro Tools and other applications/systems sounds OK? Or at a lower volume? Is it just an issue with say the ASIO4ALL/audio card settings that a student might have messed with? You want to look at the Windows audio settigns, make sure the device assigned to system sound and the levels are all the same on all the PCs. What exact audio card/device in in the PC? What version of ASIO4ALL etc? Post a Sandra report, even better post a Sandra report for a PC that works and the one that does not. Screen shots of ASIO4ALL settings and Windows Audio Control Panel would be nice. |
Darryl, There is a tech person there (not for ProTools, though) that may help answering the points you brought up (audio/card, ASIO4ALL) as I am not so knowledgeable. I will be there this coming week and get back here (hopefully) with some updates. THANKS!!! |
Audio track shows on session, but no sound from it? | rockguitarist1255 | Pro Tools 10 | 5 | 12-05-2022 04:23 PM |
How to change click track sound? | Mike Borok | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-12-2015 09:38 AM |
No click sound on click track | sighermike | Pro Tools M-Powered (Mac) | 3 | 10-10-2012 12:01 PM |
Fast Track Pro Outputting Mic input to Monitor, but Pro Tools 8 shows no mic signal | changa86 | Pro Tools M-Powered (Mac) | 3 | 12-18-2009 10:06 PM |
SOLVED: Not able to record audio - track shows high sound | tobbenos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-31-2008 12:05 AM |
