Old 05-14-2003, 04:40 AM
Guest
Posts: n/a
Default Audiomedia III latency
Hello there,
I´m would like to know information about
the latency using Audiomedia III.
Since i never used this card, and im thinking about get one, does this card can have
zero latency, or very small, so you can record
and ear the playback tracks without getting
everything delayed?
I´ve used many cards in my life and even a
few "mseconds" make a difference...
Thanks
Old 05-14-2003, 04:01 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Audiomedia III latency
It actually depends on the software, the card itself doesn't have any real latency (other than a few samples of converter delay when doing analog I/O).
If the software's engine runs on the computer's host (instead of the card) then that's where you will experience some latency.
What app were you going to use?
linkedin
Old 05-14-2003, 04:48 PM
Guest
Posts: n/a
I see...
Well, i use Cubase VST 5.0, and i want to
use Protools LE 5.0.
Can you tell me also if its ok to use in the same computer a midi card (Yamaha SW1000XG)?
thanks
Old 05-15-2003, 01:17 PM
jeffro's Avatar
Here are a couple Answerbase articles about latency that should help...
http://answerbase.digidesign.com/detail.cfm?DID=4196
http://answerbase.digidesign.com/detail.cfm?DID=4378
linkedin
Old 05-16-2003, 12:01 AM
jeffro's Avatar
The Pro Toole LE engine runs on the computer's host. I believe it's the same with Cubase VST, but you should check with Steinberg on that.
As far as the MIDI card, http://www.digidesign.com/compato has all of our compatibility info.
linkedin
Old 05-16-2003, 12:26 AM
Guest
Posts: n/a
Ok,
But that means im going to have some latency
if i use Cubase or Protools LE?
And how much latency?
Does it go to affect the monitoring of the
recording tracks?
I got the information that the latency using
Audiomedia III it´s about 2.3 ms ....
Thanks again
Old 05-19-2003, 03:13 PM
Rock_Artist Rock_Artist is offline
My Audiomedia III gets 512Samples latency (Not SMALL) when using ASIO but I hope digi will fix that.
At Pro Tools you can easily get 128Samples (about 4ms+/- and it's pretty low).
Just wanna do music,
RA.
HTML code is On
latency with audiomedia 3 zinzin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-12-2007 11:05 PM
Latency between the M-Box and an Audiomedia III Release 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-22-2004 10:51 AM
Audiomedia III latency Tips & Tricks 1 05-14-2003 06:54 AM
Audiomedia III latency... 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-13-2003 06:34 PM
AudioMedia III latency on mac deepole General Discussion 0 01-28-2003 04:17 AM
