ProFire 2626 problem on MAC and Update problem
1. Hi there!
Just got my new iMac with ProFire2626... and stuck with it.. I made everything right, installed all the necessary drivers for soundcard. But the system (and Pro Tools M-Powered too) sees only "Multichannel Input" and "SPDIF Input", and "Multichannel Output". Driver panel shows everything is okay, I can see all the input signals, but cannot use them in my Pro Tools application....same as the outputs... the point is that the list on the left side of I/O window consists of two lines: Analog In 1-2 and SPDIF In 1-2. The same problem appears in Logic 9 too. It seems to be the problem of driver or smthg... The MAC system doesn't see all physical inputs, only first two. What the problem can be and how to solve it??? 2. Update to M-Powered 8.0.3 I downloaded from Digidesigns site: http://secure.digidesign.com/service...&localeCode=en says it has wrong CRC checksum and fails!!! what's this? thanx in advance |
Re: ProFire 2626 problem on MAC and Update problem
In Pro Tools, go to Setups>IO Setups and click on the default button on both the input and output tabs - that should fix the problem with it not showing all IO.
I'm using iMac. My OS version is 10.6.2 MacOSX Snow Leopard.
Here are the screenshots from my sound options and i/o window from Pro Tools. ***Already tried pressing "Default" button http://forums.m-audio.com/attachment...3&d=1271920345 http://forums.m-audio.com/attachment...4&d=1271920349 http://forums.m-audio.com/attachment...5&d=1271920358 http://forums.m-audio.com/attachment...6&d=1271920361 |
and what about Update Fails??
I tried downloading the .dmg file several times with different computers... Says checksum is wrong...then I press "Proceed", it goes up to 100% and shows the Error massage that update isn't installed. |
Not owning a 2626 I'm not sure how many paths you should have, but it looks like there are quite a few available that need to be defined simply by selecting "new path". Enter in a name and select "mono" or "stereo" from the pull down list, then mouse click on the channels you want for that path.
Perhaps I'm missing something.
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? | Priz | Windows | 1 | 09-25-2011 12:51 PM |
Problem Solved--Profire 2626 DSP Mixer buffer is locked on 64 Bits | ubrnostrum | Pro Tools M-Powered (Win) | 1 | 04-20-2010 12:36 PM |
Repeatable problem MP 7.4 upgraded to 8, ProFire 2626 problem | tylerparkinson | Pro Tools M-Powered (Mac) | 0 | 08-21-2009 02:20 PM |
Profire 2626 Problem, I'm completely lost. | crorr | Pro Tools M-Powered (Win) | 5 | 06-20-2009 06:43 PM |
Digi 003 and Profire 2626 Audio interface Problem!!! Please help!!! | drum269 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-11-2008 03:18 PM |
