Old 12-07-2020, 06:28 AM
Mucas46 Mucas46 is offline
Default AAF import from Premiere Pro 2020
Everything is in the title, impossible to import an AAF in 48 khz, 24bits from a Premiere Pro 2020 to my ProTools 2019 10.0.
When I start the import from ProTools, it opens the small import progress window but the bar does not load even after 30 min, the mouse cursor changes to a circle that turns and as soon as I click something share on ProTools it changes to "not responding".
InfoS about my hardware:
- Windows 10
- Intel Core i5-6600K 3.50GHz
- Pro Tools 2019 10.0
- 16 GB of RAM
- AAF imported from an External exFAT 931 GB hard drive in a folder containing the folders with the AIF exports of the audios processed on Premiere Pro 2020
AAF export was done from a Premiere Pro 2020 from a MAC
In terms of troubleshooting I did not try anything after seeing a lot of youtube tutorials which nevertheless validated my good export and import approach ...
Does anyone have any idea?
Thank you, wishing you a good day,
Lucas
Problème AAF Premiere Pro 2020 vers ProTools 10.0 [Rapport de Bug] Mucas46 Le Forum en Français 0 12-07-2020 06:04 AM
Importing Premiere OMF into PT 2020.3 B Stewart Pro Tools 2020 3 04-06-2020 03:25 PM
OMF import from Premiere cs6 into PT 10 problem bebeuriarte Windows 3 09-28-2013 03:06 PM
Import audio from Premiere Pro 2.0 Flaf Post - Surround - Video 0 01-06-2007 11:31 AM
AAF Import from Premiere FlorianE Post - Surround - Video 6 07-28-2006 06:24 AM
