#1311
Re: Best Core 2 Series Desktops-Results and Specs
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#1312
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#1313
3 Days ago? you got a early card pretty quick. Nice to see a non paper launch for a change also.
#1314
AUDIO CONFIG.
HI There!! I just started to use my Mbox 2 Pro yesterday and I´ve got a problem with monitors. I have the KRK RP-8 and I already made the conections, Right Monitor to the MON OUT RIGHT, and Left Monitor to the MON OUT LEFT output of the Mbox. I can hear what I record, buy I also listen interference noises even some windows interference noises. I don´t understand what happen.. I already configure the Mbox as the playback default device, is it that right?? Please some help on how to config the Audio Output on Pro Tools!!! Thanks a lot
Dont Stop for Nothing, its full speed or Nothing! |
#1315
Re: AUDIO CONFIG.
first, not being rude but please post this in the correct thread for this kind of a post!!!
second, 2 things, you say interferance noises which is kinda vague. do you mean bleeps and blips and sound from windows, or do you mean like static and ground hum?? not sure from your post. please move this post out of this thread and into the main pt le for windows.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#1316
#1317
Yes I manually set voltages to the NB and South Bridge. I wouldn't go for more than 1.55 on the NB and no more than 1.5 on the SB.
#1318
thanks man. is there a tool that you use that displays the current voltages of one's mobo???
also, pls list your specs so i can post your build on page 1. thanks
#1319
Everest will list voltages.
My system specs: Asus Mongrel Formula SE X38 (Maximus Formula SE with Rampage Formula 0403 BIOS) Q6600 G0 SLACR - Noctua NH-U12P 2Gb Mushkin XP2-8500 512Mb BFG Geforce 8800GT OC (G92) ADS Pyro 64 (onboard firewire does work too) Pioneer 215 DVD-RW - SATA Corsair HX520 WD 74Gb Raptor (OS)/WD 500Gb AAKS/Seagate 320Gb/ WD 200Gb - All SATA Win XP Pro SP3 - PT LE 7.4cs5/MP Toolkit/Digi 003R |
#1320
The Bad Dawg DAW
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
