ProControl issue
once in a while, my pro control while being in a session will turn off all LEDs and slam the faders down hard, and will remain that way.
its only the mainunit that does, and i have to turn it off and wait several hours before it goes away, then i can turn it on the next day and have the problem gone for months. i soldered the main connecter to the psu inside the main unit, that caused a few glitches earlier but thats all fixed. any of you have ever tried this? its only when pt is open if the procontrol is offline it wont happen |
Re: ProControl issue
Could be a network issue. If you have more than just the Main Unit, you should NOT use a crossover cable. This causes random issues. The crossover cable is only if you have just the main unit only. Also, make sure you do not have anything else on the same network. If going to a DSP router, use one of the two ports on the Mac Pro for that, and the other for just the ProControl units.
You could have issues with your Cat5 cables, or your hub. I would troubleshoot that before taking the unit apart.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
thanks for that :)
the mainunit snd the faderpack goes into a hub, that goes into one of the mac pro ports. i actually dont know if im uding a crossover cable? |
I assume you have swapped out all your ethernet cables and the hub and tried different onees to rule that out?
It was me who advised you to solder the big connector straight to the PSU, I know for sure this helped out a lot of people, including myself. What you are experiencing now has probably nothing to do with ethernet cabling and the possible use of a crossover cables because you would have had problems from day one. The symptoms you are describing point again to a temporary PSU failure, 99% chance again it is not the PSU itself but the power connectors, this time on the circuit boards. The solution is exactly the same as before: check the power connectors on the circuit boards, clean them and reseat them, or consider the best solution: remove the connectors and solder the wires straight to the circuit board (you did it once on the PSU, do it again on the circuit boards, the connectors have the same wire colouring: red-yellow-black). It all has to do with oxidation in-between the contact busses in the connector and the contact pins on the circuit board that eventually create a much too small contact surface that eventually heats up and becomes unstable. The contact points on the PSU are prone to this first as a PSU carries the highest power load (the full machine), while the contact points on each circuit board carry less power so they oxidise slower and last longer. Probably cleaning and reseating the power connectors on the circuit boards will do the trick for a long time, but soldering the wires straight to the circuit board will fix the problem forever. @ Barry: using a crossover cable with a hub was a big problem in the early days, todays hubs work fine with any ethernet cable, the hub automatically checks all the cable configurations and adapts to a single or multiple crossing cable configuration if necessary. But of course it is correct to check the ethernet connections first, before attacking your ProControl with a soldering iron
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins Last edited by Delta Music Belgium; 09-15-2014 at 09:29 AM. |
thanks delta! yes the soldering did wonders, and the only issue left is the issue i posted here. i will go on and solder the rest thanks!:)
weird crash issue PTx and possible procontrol issue, need help | Cryos | Pro Tools 10 | 5 | 12-08-2011 05:17 PM |
Digi 002 Power Harness Issue or Firewire Chip Issue? | Nish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 35 | 05-07-2010 01:25 PM |
002 Console Issue, Faders Wont Move (grounding issue?) | guitar486 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-01-2010 03:58 PM |
!!!!!Procontrol with 7.3.1cs4- Numeric keyboard issue!!!!! | Cryos | ProControl, Control|24, Command|8 | 1 | 09-16-2007 10:20 AM |
'Fader Pack' and ProControl Fader order issue | Ciaran | ProControl, Control|24, Command|8 | 2 | 03-21-2005 11:58 PM |
