Old 09-17-2017, 11:33 AM
amayesing1 amayesing1 is offline
Default all my old music
i was recording midi and audio on pro tools 8 m powered and now im using pro tools 12.8. how do i go back and get all of my music files from pro tools 8 m powered to put into pro tools 12.8
thank for your help anthony
Old 09-17-2017, 11:55 AM
john1192 john1192 is offline
Default Re: all my old music
did you keep your old system running ?? if so, you could consolidate your tracks and bring them over ..
if not, have you tired "import session data" from an older session ?? i cannot remember if you can open those older files in PT12 ... but i have PT10 here and i know that will ... maybe i can help you get one open as a test if you need
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 09-17-2017, 02:07 PM
Barry Johns Barry Johns is offline
Protools 12 also comes with Protools 10, use 10 to get them ready for 12
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 09-18-2017, 09:56 AM
The Weed's Avatar
The Weed The Weed is offline
And install PT10 before you install PT12.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-18-2017, 06:57 PM
Unless the old projects are done in SD II format, they should open(and then you would Save As to convert to the current file format)
Old 09-19-2017, 10:01 AM
Inglesworth Inglesworth is offline
You should just be able to open your .ptf sessions with PT 12. The first time you attempt to save, pro tools will force you to do a save as, and it will save the file as the newer .ptx format.
As mentioned earlier, unless you were using SD2 files, it should work ust fine. If I'm not mistaken, I believe PT8 already had the ability to create SD2 files removed, but it was still able to read them. You should be fine.
Old 09-19-2017, 10:21 AM
JoelG's Avatar
JoelG JoelG is offline
As long as any plugins used where upgraded to AAX..
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
OMFs from Premiere with MP3 music files have clicks in the music jyellen Post - Surround - Video 4 08-15-2017 08:46 AM
DAW's and music PMoshay Pro Tools TDM Systems (Mac) 2 01-05-2006 08:11 PM
music packages for music video shoots cwholden Post - Surround - Video 0 03-07-2005 01:37 AM
It's about the music! not PT 6.0 eye2iRt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-02-2003 10:28 AM
FILM MUSIC 101: HOW TO SELL YOURSELF IN THE FILM & TV MUSIC MARKETPLACE John Link General Discussion 3 06-04-2002 10:01 AM
