2 IDE/HDs, partions, boot drive questions...
I'm a planning on buying a Digi001 and running it on my MacG4/400(saw), 256MbRAM, 20GbHD, OS9.0.4. I'm adding another internal IDE/HD (IBM Deskstar 75GXP, 75Gb, 7200RPM, Ultra ATA/100) as a dedicated audio drive.
After reading posts about troubles encountered after installing ProToolsLE (DVD player not working, computer won't boot, system-wide slow downs, etc.), I'm a bit concerned. The G4 is my main computer, which I depend on for other work/personal related tasks. My question is: Is it possible to allocate a partition of the new HD for a clean install of OS9 & PT/LE, then select it as the boot drive only when I want to run PT/LE? Could I then boot off the original HD for everyday use? I've replaced an internal IDE/HD before, but never added a 2nd one. Are there issues that would make this approach unfeasible? I recall reading something about having to flip dip switches for slave/master settings. Can you swap which (internal) drive you boot from on the fly, or at least without having to open the case? Thanks for any info. Robb Houston www.robbhouston.com [Sorry about the cross-post to the Mac/Digi001 group. I just started monitoring this discussion group. New to the site.] |
ProTools Boot drive migration to a new internal SATA drive | audiowave | Pro Tools TDM Systems (Mac) | 1 | 05-03-2011 03:45 PM |
Converting MPC3000 Zips w/Partions | M2E | General Discussion | 1 | 03-13-2004 08:18 PM |
Boot Drive/Audio drive -SCSI? | JimiTM | Storage Subsystems | 2 | 08-09-2000 12:04 AM |
2 IDE/HDs, partions, boot drive questions... | robbhouston | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-05-2000 07:44 AM |
NTFS Partions | Steve Rosenthal | Pro Tools TDM Systems (Win) | 6 | 02-17-1999 06:53 PM |
