Old 01-06-2012, 07:05 PM
Polaris Polaris is offline
Default MComposer Automation Not Translating to PT
We are seeing errors and omission in the automation from the picture editor's avid being translated to a PT10 session. We have tried all the combinations in the AAF import window but none seem to be correct. There are clips that should be playing that do not and vice versa.
As a test, I went back and tried in PT9 and was able to successfully import the correct automation.
Anyone else seeing this behavior?
Cheers
MacPro
PT10.0HD
TDM HD1
Polaris
Old 01-06-2012, 07:33 PM
Craig F Craig F is offline
Default Re: MComposer Automation Not Translating to PT
what version(s) of MC?
is it making it to Clip Gain?
Thank you,
Craig
Old 01-09-2012, 11:24 AM
it is MC v5.0.4. and yes, I seem to be able to get clip gain or auto moves but not both.
From my testing, it seems PT9 does more of a "coalesce" of the two types of automation rather than what PT10 does which appears to be a "convert" in PT parlance. The picture editor is using both clip gain and rubber band gain. He'll gain down an alternate using clip gain, then at a later date gain it back up using rubber band gain. Not ideal but its what we got.
There just does not seem to be a way to achieve an AAF conversion in PT10 similar to how it was handled in PT9 which is odd given that PT10 adds these new clip gain features.
Are you seeing similar results by chance? I've made some snapshots as examples. Some of this is subtle but other areas are extreme. Bottom track is a guide. (note the huge gain difference around 520').
Here's what it should look like as created by PT9 (convert clip gain to auto):
https://picasaweb.google.com/lh/phot...eat=directlink
Here's what PT10 is producing (Import clip gain & auto):
(Import Clip gain NOT checked)
Its a head scratcher...
Polaris
Old 01-09-2012, 11:51 AM
C C is offline
Achieving the same result in 9 and 10 is a two stage process.
First import as clip gain then "coalesce clip gain to volume automation" from Edit > Automation menu. Results in the "coalesce" that you've previously known.
Ceri
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 01-09-2012, 12:18 PM
Thanks C.
I had tried that as well and it does not work either. Here's is a typical problem: AAF has a region volume graph = -∞dB but clip gain = 0dB. In PT9, that region comes in at 0dB but in PT10 at -∞dB; no matter what combination of import settings.
Perhaps this is a larger problem of PT10 just not converting automation correctly but its happening a lot on our AAFs.
At any rate, the PT9 session matches the guide track, the PT10 session does not. Just wondering if we are the only ones seeing this.
Cheers,
Polaris
Old 01-09-2012, 01:26 PM
C C is offline
Yes I have seen this before. Does it occur on more than one file for you? I had it happen once a little while ago and couldn't reproduce with another AAF.
Ceri Thomas
Personal Site
Old 01-09-2012, 01:37 PM
jglasgow jglasgow is offline
It turns out this is a known issue. We expect to have a fix very soon.
Best,
Old 01-09-2012, 02:03 PM
Ah, thank you for the confirmation. I was beginning to worry it was just us.
Glad there is a fix in the works.
@ Ceri - yes, we are seeing it in large and small differences in several AAF's.
Polaris
DNS2000 on PT HD 8.0.3 Automation Translating Incorrectly? zseivers Post - Surround - Video 2 01-06-2010 02:51 PM
translating cedar dns2000 automation os9->osx? Matt Chan Post - Surround - Video 0 05-17-2005 11:36 AM
Mixes not Translating well Slade General Discussion 11 01-12-2005 09:36 AM
Translating PC sessions to Mac TDM? MAProTulz Pro Tools TDM Systems (Win) 2 02-16-2001 12:23 AM
Translating PC sessions to Mac? MAProTulz General Discussion 0 02-05-2001 06:38 AM
