Old 04-04-2020, 08:22 AM
rmanno rmanno is offline
Default Guitar Amps/Cabs
I have an issue while trying to record guitar while in Pro Tools First. Clean guitar is not a problem.
However, I cannot for the life of me get a rock or metal tone. Using the pedals and effects is horrible. Tinny, weak and no balls whatsoever.
I know you can do it. What am I missing? There are supposed to be amps and cabs that you can use, however I for the life of me cannot find them or find an add on that will do it. Do I need to buy a plug in?
Also I got the Focusrite drum pack download but all that are in it are a bunch of folders. I am assuming that I need to copy them but have no idea where.
Thanks in advance!
Old 04-04-2020, 08:51 AM
Default Re: Guitar Amps/Cabs
Is "Eleven" part of PT First? The biggest issue with PT First is that it does not allow for 3rd party plugins unless you buy thru the Avid store(I think). Direct recording of guitar is not going to be good without a decent amp sim plugin. There are many that will do a nice job(Guitar Rig, Amplitube?), but they require the regular version of Pro Tools. If you're on a tight budget, there are some other DAW programs that are very capable and less expensive(Reaper and Studio One come to mind). The other option is to get a decent sound before recording. A small tube amp in a closet? A used Digidesign Eleven Rack?
Old 04-04-2020, 09:13 AM
Thanks Dave. That is what I figured. For $30 a year I don't think its that bad.
It comes with Eleven "Lite" which I guess does not include the AMPS/CAB modeling. I hear you about small tube amp but I want to avoid that at this time.
Are you able to upgrade First into regular? Or will I need to uninstall all the crap I've installed over the past 2 days?
Thanks again!
Old 04-04-2020, 12:16 PM
Thanks again!
AFAIK, you can simply uninstall PTF and install the full version. Just make sure you have your iLok loaded with the full license before pulling the trigger
Software Missing Many Cabs, Amps, Etc? Alien Frequency Eleven Rack 11 04-07-2016 10:21 PM
Marshall, Egnater, Avatar amps and cabs for sale!! desmondtencents Buy & Sell 2 02-09-2015 05:17 AM
Amplitube - New ENGL Officially licensed amps/cabs nst7 Eleven Rack 9 04-25-2014 05:55 AM
Two amps two cabs kittybite Eleven Rack 4 08-04-2012 12:35 AM
Mic guitar cabs- XY or Near/Far? What do you use? bkremer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-20-2005 02:20 AM
