Old 03-22-2017, 04:50 AM
erik.smeets erik.smeets is offline
Default Euphonix Avid Artist / Eucon MC Control Cubase 9 64 bit OSX Yosemitecompatibility
sorry for starting a new thread but it's the same question as my other thread about the Mix: http://duc.avid.com/showthread.php?t=389799
Any Euphonix MC Mix / AVID Artist Mix users here that work with Cubase Pro 9 on OS X 10.10 Yosemite? (64 bit)
Does it work? Any pros and cons?
Which drivers do I have to install etc?
Thank you
Old 04-10-2017, 02:21 AM
Aliensix Aliensix is offline
Default Re: Euphonix Avid Artist / Eucon MC Control Cubase 9 64 bit OSX Yosemitecompatibility
Hi there, your subject mentions Artist/ MC Control, so I thought I'd share my experiences since I moved over to Cubase Pro 9 a couple of weeks ago.
Functionality seems pretty much the same as with Cubase 8.5 although the new Sampler track is not recognised by MC Control. I assign a group track or VCA to it to make it visible on the MC Control. I'd recommend assigning it to a group track though if you intend to insert VST's.
The track attentioning seems a little hit and miss. If I added an FX channel to the selected track it would follow and focus on the new FX track, but in a large project it forgets to do that! A little annoying but not a deal breaker.
Apart from those points I've not yet come across anything else.
I hope that's of use to you.
Best
Geoff
Old 04-10-2017, 05:33 PM
EddieJones's Avatar
Geoff
I'm sure they are aware but just incase can you report this to Steinberg too.
Euphonix MC Mix / AVID Artist Mix Cubase 9 compatibility erik.smeets Artist Series 3 03-22-2017 06:03 AM
Euphonix MC Mix / AVID Artist Mix Cubase 8.5 OSX compatibility erik.smeets Artist Series 1 11-22-2016 08:21 AM
Issue with pan pot on euphonix mc control eucon v2 austinperezmusic Artist Series 16 01-07-2015 02:21 AM
Euphonix MC Mix vs. Avid Artist Mix ?? jacknprewitt Artist Series 3 04-11-2014 12:09 PM
Avid Artist Control vs Euphonix MC Control? DAWgEAR Artist Series 3 10-22-2012 07:10 AM
