Warning: Waves V5
i noticed on the Waves website that version 5 is available so I thought I'd download it because it had a couple of cool features. So far it doesn't work well. I tried a couple of sessions that had a fair amount of waves plguins (around 25 or so) that ran well with version 4.05 - errors within a few seconds. I reinstalled version 4.05 and things seems to work again. If anyone else has better luck let me know as I would like to stay current, but I need to finish up a couple of sessions first.
G5 1.8DP 4 gig ram, 002 Waves Platinum, UAD-1 Studio Pak, Reason 2.5, BFD Presonus Digimax 96K, UA 6176, Mackie Onyx 1640 |
Re: Warning: Waves V5
can you please test if removing some plugs (five or so) helps getting rid of the errors? it might be that the new versions are not yet optimized thus having lower performance than the older probably optimized plugs. how many plugs you need to remove to get rid of the errors? i'm expecting a 10% performance loss - you're in a good position to test it
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
one has to be brave to use dot-zero software in production environment, period.
I personally only use a few Waves PIs as I only have Native bundles. Day to day I am using a TDM system so I use a lot of TDM plugs in my sessions and only a few RTAS. However, hopefully there won't be a negative change in efficiency using LE with RTAS when I try it with my 002r. Maybe we need a few more posts from users with heavily Waves loaded sessions who are now running out of CPU to conclude that efficiency is down and not just a preconception?
I agree, little should be assumed based on version number, especially when there's so little change. There are almost no new features in the V5 Waves bundle. I haven't installed them on my PC yet, but I installed the demo on my Mac, and didn't notice anything new on the handful of plugs I checked.
I was pleased that Waves didn't charge me anything for the 4.05->5 update; they realize there's nothing new there.
Quad 2.5 G5, 4.5G RAM |
dk
www.dpksound.com |
the reason i'm worried about the possible performance loss is because just recently i had to reinstall my whole system and during that process it was more convenient for me to install v5 plugins. i have the renaissance bundle and the musicians bundle, and have used to use a lot of renaissance channel plug... so it's not trivial whether i can put in ten or twenty of those. please, someone who has a maxxed out v4 session try how many plugs needs to be removed to get rid of the errors...
Tempo Sync - Four plug-ins have been upgraded with a new feature of automatic tempo sync. The plug-ins are: Enigma, MetaFlanger, MondoMod and SuperTap. The new functionality enables those plug-ins to lock to the host application’s tempo and tie the relevant controls to that externally controlled tempo. Morphoder MIDI Control - Morphoder, part of the Transform bundle, now becomes a true virtual instrument. In all supported host applications you will be able to assign a MIDI track output to an open instance of the Morphoder and play its internal carrier from a MIDI track using recorded MIDI data or live playback from a MIDI controller. Waves 360° Bundle for Windows - The Waves 360° Surround Tools Bundle is now available for ProTools TDM running on Windows. Waves 360° Bundle – Native - On both Mac & PC, the Waves 360° Bundle now supports Native processing, running as RTAS & HTDM. HTDM Support - All Waves plug-ins now support Digidesign’s HTDM architecture, enabling Native processing while maintaining important TDM functionalities such as changing a track’s number of outputs (mono ->stereo, mono/stereo ->surround), inserting a plug-in on Aux and/or Master tracks and more. Note! – ProTools TDM 6.4cs4 update is required for HTDM support http://www.digidesign.com/download/cs/ HD Accel Support for Windows - Digidesign’s new HD Accel hardware is now supported for Windows. 96kHz Support On HD Accel - Several plug-ins are now supported at 96kHz sample rate on Digidesign’s new HD Accel DSP cards. The enhanced plug-ins are: C4, SuperTap*, Morphoder, LinMB, LinEQ (Broadband Mono component only). * SuperTap is now also supported up to 192khz in Native process. Digi 002 and Command/8 Control Surface support - All Waves plug-ins are now officially mapped to Digidesign’s Digi 002 and Command|8 control surfaces. Automatic Delay Compensation support for Pro Tools - All Waves plug-ins are adapted to support the new Automatic Delay Compensation feature in ProTools 6.4 of these it looks like good updates (to me) for the LE users the ones that i cane see are; Quote:
also i have used up a session with 4.05 plug's and have noticed with 5.0 i hit the wall sooner while playing through. now i DO NOT believe in the dot-zero release = crap stuff. that is alot of misinformation if you ask me. i have worked in the industry 8+ years and i am here to tell you (again) that any release has the potential to slow down areas and speed up others. no one type of release is supposedly faster/more stable than any other. at least not by following a dot-sero = crap mentality. that said there is a decrease in performance there. ironically (and i am just throwing this out as a reference) there is no speed decrease in logic. BIG DISCLAMER AGAIN: i do not endorse one or the other for recording i only have access to both and noticed that the rtas plugins for digi are slower. NOTE: the plugins for Logic are AU and closer to apple. since i am on a mac (Of course) this could be the reason why. 2 cents, ken;
What is Ken Hawkins up to? |
Not all Waves plugs are equal, so you're not likely to get a useful response to a question like that.
Some individual tests are possible, for instance, number of Rverb instances which will run in each version. That might tell you something.
*WARNING* Waves IDR whacked!!!!! | Top Jimmy | General Discussion | 27 | 07-31-2011 04:18 PM |
major Waves TLC warning | Mark Dann | Pro Tools TDM Systems (Mac) | 29 | 07-06-2009 08:21 PM |
Hey everyone! warning O.T.-O.T. | GORILLA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-31-2003 05:56 AM |
Waves 3.5 and PTLE 5.1 WARNING! | citi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-18-2002 12:56 AM |
WAVES 3.5 warning !!! | Dutchmuzik | Pro Tools TDM Systems (Mac) | 14 | 06-18-2002 06:45 PM |
