MIDI Note not displaying exactly at start of beat?
Hey guys
Is this user error or a "feature" ? Note looks bang on in edit window, but early in *** MIDIedit*** window..... Thanks :) Last edited by midnightrambler; 06-05-2015 at 08:50 AM. Reason: *** Changed mix window to midi window |
Hmm, I have another one here. I'll check on 11 in a bit and see if it's the same.
I see two edit windows - the MIDI editor window and the main PT Edit window. No mix window. What shows in the MIDI event list? Are these notes you played in or entered manually? Try entering manually in either the MIDI event list or the MIDI editor and see what happens. I don't think it's user error or a 'feature'. Might be a graphics issue.
I didn't mean mix window, sorry, I meant midi edit window, my mistake. I will try the things you've suggested.
Okay. You may find you get a couple of things that agree with each other and one that doesn't. That's why I mentioned about manually entering MIDI notes in any of the places (event list, MIDI editor, etc.) that way the timing of your input won't be in question.
if you zoom way, way in, while in the Edit window the notes look off the grid as well, correct ??? in notes view should be the same as the MidiEditor ... you are looking in clip or block view right ??
Re: MIDI Note not displaying exactly at start of beat?
Do you have any midi realtime properties enabled? There is a preference I think for realtime properties to be displayed or not, perhaps it is not working the same in the midi editor and edit window.
Steve Peach Stereo Missile Recordings Creative Director - Red Note Visionary Sounds: http://rednote.com.au Label: http://www.stereomissile.com/ Music Production / Mixing: http://www.stereomissile.com/musicproducer/ Mastering: http://www.stereomissile.com/mastering/ |
This preference with MRTP shouldn't give any visual discrepancy between editor windows.
Tried to make this happen on my system, but couldn't.
Thanks Stig.
I just opened up a brand new session - new instrument track - drew in a MIDI note at bar 9. Now it appears I can drag the MIDI note manually in slip mode before bar 9 visually but it still registers as bar 9 on the MIDI selection start (see screen grabs) - this doesn't make much sense to me. Maybe it's always been like this and I've never noticed? I'm just going to check if this is the same in 11. |
Can't place MIDI-note exact on beat | nothe | Windows | 0 | 10-22-2012 03:40 PM |
Midi 101 really missing? Set high note/low note on track's input | robinsonsdca | macOS | 4 | 11-10-2011 01:23 PM |
Beat detective and 8th note triplets... | O.G. Killa | Pro Tools TDM Systems (Mac) | 6 | 11-19-2009 10:48 AM |
MIDI Wait For Note start delay | HearInc | Pro Tools TDM Systems (Mac) | 16 | 02-05-2009 03:52 PM |
EXPORT MIDI from Stryke NOTE FOR NOTE... |
riggi | Virtual Instruments | 1 | 03-10-2008 07:32 PM |
