merging midi two midi parts into one ???
- being a Logic user (as well) I find it useful sometimes to be able to split midi into two parts and then later merge them together...how do I merge two different midi tracks into one ???
thanks |
Re: merging midi two midi parts into one ???
Note: To merge 2 regions: Edit > Consolidate.
macpro 2.6ghz, 4gb ram, osx 10.6.1, macbookpro 2.5ghz, 4gb ram, osx 10.5.8 mbox2pro, mbox2micro, emu1616, protools8le, reaper, logic express, axiompro49, padkontrol, rode nt2-a, lexicon mx300, uad2laptop r3, microQ, Albino3, impOSCar, Structure m1active 520 & sub gw s750, deq230, cx2310 |
but if he came from logic, then he´s used to merge midi regions from DIFFERENT tracks
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
(i have 2nd monitor and windows configurations preset with "Edit" window opened on first monitor and "MIDI editor" window opened on second monitor. So it minimize mouse clicks)
Unless I'm seriously misunderstanding your question alt-m is what you're after. Select one track, hit apple-a to select all the midi data, then either cut or copy everything. Then place your insertion cursor at the same place on the destination track and hit alt-m to merge the 2 tracks.
Is alt m a shortcut for this suicine You can also paste and merge MIDI notes using Paste Special commands. See “Special Paste Function for Automation Data RTFM I always thought it wasn't there because it is made quite obvious in DP. DUC educates again.
Denis Mac Pro 3.3 hexacore 24 gb RAM Lion PT 10 HD Native |
Mind you I should point out that PT doesn't preserve channel information on a per-event basis the way Logic does - so if you are attempting to merge 2 tracks routed to different channels on a multi-timbral instrument I'm afraid you can't do this in PT the way you can in logic.
Don't worry about it, that's what we're here for! |
thanks guys !! very useful !!
just found this when searching for how to flatten a bunch of separate midi tracks. this works fine, tho it's too bad you can't do it in a single step.
__________________ Al Hospers bassist, vocal, composer, engineer https://www.youtube.com/channel/UCCw...ogfR_7Q/videos ------------------------------------------------------ PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones... |
Merging Midi Tracks | txshonk | Pro Tools 10 | 5 | 02-24-2013 07:07 PM |
Committing midi parts to audio. All parts ahead of bar line | sad1robot | Pro Tools TDM Systems (Mac) | 2 | 04-25-2010 01:09 AM |
Merging MIDI | bontay | MIDI | 2 | 03-20-2010 10:09 PM |
Merging midi tracks, is it possible? | Ruben_B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-12-2004 06:27 AM |
Merging Midi? | Dopamine | MIDI | 1 | 06-17-2004 04:24 PM |
