Pro Tools First Install Help
Happy new year everyone.
I recently received a Focusrite 18i8 which came with the free download of Pro Tools First. I've been trying install it but when I try to run the program, I receive a message that says "AAE error - 13001 was encountered. Not enough privileges to raise priority of a thread. Bad Installer?". After I click "Okay", another message pops up that says "Assertion in "..\ SMgr_StConnectionPrep.cpp", line 152. (Use the Copy Button to copy this message to the clipboard.) After that, it just says Initializing Hardware and does nothing. Im running this on Windows 7 Home Premium. Im not very tech saavy...any help is greatly appreciated before throwing my old laptop out the window. |
Re: Pro Tools First Install Help
When you run Pro Tools, can you try right clicking on the icon and choosing Run as administrator? Also try holding down the N key while PT is loading. This will force a a playback engine refresh and should let you choose your audio interface.
If neither of these work, I would uninstall Pro Tools from your system and try reinstalling it. This time, right click on the installer and choose Run as administrator. If that doesn't work, then we will most likely need a bit more information about your system to try and see where the problem might be. Give it a try and report back. |
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! | shamanrock | Windows | 13 | 12-27-2012 04:39 PM |
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions | b-pole | macOS | 2 | 08-31-2011 07:23 AM |
Can't install Pro Tools 8! Clean install, new system, Vista! | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 01-09-2011 11:16 AM |
Can't install Pro Tools LE - Insert disc but no option to install | Paul McConnell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-22-2010 08:13 AM |
Why install Pro-Tools to install drivers for Mbox2 | bigbobbysd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2010 07:42 AM |
