If I got Pro Tools HD 3 PCIe & a Magma PE6R4 Expansion would Pro Tools HD run as a true 64bit application? Thus using more then 4GB of RAM?
Currently, from what I understand, 32bit apps are limited to 4GB of RAM usage per app. because of the OS. I'd be running Pro Tools HD 7.4.1 on a Mac Pro 3.0GHz x2 8-core with Leopard OS X 10.5.1 |
![]() Quote:
http://www.digidesign.com/index.cfm?...4&itemid=29589 Pro Tools HD 7.4.1 requires ONE of the following Pro Tools|HD configurations: Pro Tools|HD 1, HD 2, or HD 3 PCIe system — 1 Accel Core card and up to 2 HD Accel cards (PCIe) HD PCIe Cards must be installed inside the Mac Pro See Pro Tools HD 7.4.1 Read Me for information on installation instructions of third HD Accel PCIe card in slot 4 Up to 6 Pro Tools|HD PCI Cards — installed inside the Magma PE6R4 6-slot expansion chassis Pro Tools|HD PCI and Pro Tools|HD PCIe cards cannot be combined in any system For more information, see the Magma PE6R4 Expansion Chassis compatibility page |
I did some reading and I think it makes sense. The Magma is for adding older cards to newer computers, and doesn't make the entire Pro Tools HD application 64bit.
Pro Tools is not a 64 bit app.
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2018.3. Sierra 192 IO and 96 IO TDM user way back. PT user since 98. |
I think that you are confused...
The Magma P6R4 is ONLY for PCI-X HD cards (no PCIe), the host card and chasis works at 64bit (the PCI slot inside chasis are PCI-X, 64 bit), you can install 6 Digi cards (Process and/or Accel). Protools is a 32bit App (the software and Motorola DSPs are 32bit resolution, the internal procesing is 24bitx2=48bit), the PCI-X digi cards has a 64bit conection (PCI-X), I don´t know the reasons... The real advantage of having a 64 bit chassis is that you haven´t bandwidth limits in Protools's hardware specifications (number of voices), the 32 bit chassis reduce the capacities of a HD systems. The new Magma chasis only works with 4x PCIe host card, older Magma 6 cards PCI expAansion chasis can works with PCIe 1x and PCI cards, but I do not recomends it for limit bandwidth reasons (and compability and latency problems). |
![]() Quote:
FS: Magma PE6R4 chassis w/ cable and PCIe control card | WildHoney | Buy & Sell | 1 | 10-06-2013 03:28 PM |
WTB: Magma PE6R4 Expansion Chassis | MichaelLewisMusic | Buy & Sell | 8 | 07-20-2012 10:57 AM |
FS: Magma Expansion Chassis PE6R4 (Denmark) | Peterjk | Buy & Sell | 4 | 07-09-2012 10:33 PM |
Anyone Run PT 8 TDM with the Magma PE6R4 Expansion Chassis | kd_special | Post - Surround - Video | 4 | 09-23-2010 07:26 PM |
Magma PE6R4 PCIe x4 plugging into Intel Mac PCIe x16 slot? | soloan | Pro Tools TDM Systems (Mac) | 2 | 04-27-2010 01:42 PM |
