Old 05-25-2018, 10:53 AM
hco7777 hco7777 is offline
Default ProTools 2018.4 No Longer Muting Eleven Rack
I'm having a problem with ProTools 2018.4 and Eleven Rack (I use a macbook pro, early 2013, 2.7 GHz Intel Core i7 and Operating System High Sierra 10.13.4). I'm going to try to give all of the info about my problem, but I'm fairly new to all of this, so please forgive me if I'm not explaining things well.
I use 11Rack as my interface and as my Playback Engine. It used to be that when I would set up a new track for recording, I'd set the I/O for the track with the Interface as Eleven Rig L/R and the Output as Main Out L/R.
When I would arm the track to Record, if I muted the track, I would no longer hear the guitar signal coming in (although I could see that it was from the meter bars on the track). Now, when I mute the track, I still here my guitar signal. It mutes the track during playback, but doesn't mute the guitar signal during recording.
In terms of the Options settings: I have Pre-Fader Metering, Delay Compensation, and Low Latency Monitoring engaged.
To the best of my knowledge, I've not changed any settings on either ProTools or the 11Rack. How do I fix/restore/set things up so that when I mute the armed recording track, I no longer hear the incoming signal?
Thanks for any help and advice!
Old 05-25-2018, 11:35 AM
Turn off track input monitoring. The "I" button.
Eucon 2018.3 Problems - Monitoring Mute No Longer working BScout Avid S1, S3, Dock and Control App 4 03-07-2018 08:13 PM
Protools HDX and Eleven Rack Issues [email protected] Eleven Rack 5 08-06-2014 09:09 AM
Eleven Rack no longer available on GC/MF derker Eleven Rack 10 03-10-2013 10:19 AM
Protools HD Crashes with Eleven Rack on??? DHG MUSIC Eleven Rack 24 04-02-2011 05:45 PM
