Old 12-23-2017, 03:30 AM
blackwolf87 blackwolf87 is offline
Default Pro Tools 12.8.3 - Linking two channels in reverse volume ?
Hey folks!
Is there a way to link two channels (by grouping them up, or whatever) in a volume reverse mode? In other words, it is possible to go up and down with a fader on one chanel and get the opposite loudness changes on the other chanel?
Thank you!
Old 12-23-2017, 03:32 AM
climber climber is offline
Default Re: Pro Tools 12.8.3 - Linking two channels in reverse volume ?
So like a crossfade, but using a single fader? Not that I know of.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 12-23-2017, 04:04 AM
Stig Eliassen's Avatar
Well, sort of...
- duplicate track A (you now have to identical tracks of track A)
- insert trim plugin on both (A and A.dup)
- flip the polarity on one of them
- create a mix group with A.dup and B linking the volume
- riding the volume on track B will cancel out track A gradually
Old 12-23-2017, 06:00 AM
Ben Jenssen's Avatar
Here's an idea:
• Create a mono aux with signal generator with a sinus wave or noise, doesn't matter. Create a mono-to-stereo send, to f.ex bus 1-2.
• Now you can take any two mono tracks and insert a gate/expander on each. Set the gates to be side chained to bus 1 and 2, respectively.
• Now you should be able to use the pan control on the send to do that thing. And it should be pretty flexible.
You would need a pretty versatile gate/expander.
I never did this myself, but it should be feasible.
Edit: Of course, it doesn't have to be a send on the aux with the signal generator, you can set the noise track output to bus 1-2, and just use the regular output pan.
Old 08-14-2020, 10:31 AM
DFT DFT is offline
What a shame! This would be so useful for parallel processing to keep constant level while adjusting blend of original track and processed track.
Melda's MRatio can do this using two aux tracks and side chain input from an aux repeating the original source to MRatio hosted on the second aux with processing ... but it doesn't seem to work in PT.
PT10 Win7 x64 Dell 690P Dual Dualcore Xeon 3.0Ghz 16Gb Ram, UAD2 Quad (2), Steinberg MIDEX8 (2), RME HDSPe and A&H ZED R16 FW.
Reverse button in Pro Tools 12 HD Ianduarte Pro Tools 12 41 08-29-2015 01:32 PM
Low Volume on Channels 3 & 4? dustinsleeping Getting Started 8 07-05-2014 10:39 PM
SC48 pops when linking or un linking stereo channels lorenaguey VENUE Live Sound Systems 7 07-16-2013 08:11 AM
Xpand2 - No independent volume control of the 4 channels Richard901 Virtual Instruments 19 05-23-2009 03:42 PM
linking either dynamics or plugins across channels protourman VENUE Live Sound Systems 1 05-30-2007 11:09 PM
