#21
Re: Omni with 192 Issues/Questions
I've never tried to do exactly this but shouldn't you be able to setup the Hardware and IO panels to do this?
Basically Mirror the outputs of Ch1-8 to the ADAT connections? I assumed this was possible.....maybe I am wrong but definitely worth poking around in there to try to find out. But if push comes to shove and all you have to do is create another track and assign in/outs....it's not a major setback.
#22
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
#23
Ahhh, ok gotcha.
#24
Keep in mind that the optical outputs of the 192 will not work at all until properly configured under Setup>Hardware(inside PT). By default, digital IO is NOT set to use the lightpipe connections(IIRC, it defaults to AES). Getting the ADAT setup is not exactly intuitive(as I found when trying to use both ADAT in/out for an OctoPre preamps and headphone outputs). Once that is configured, you MIGHT be able to route with some AUX tracks that would not chew up system resources
#25
Just got my Omni. Some questions... | PostHuman | Pro Tools TDM Systems (Mac) | 9 | 06-03-2023 02:06 PM |
Omni-192 Expansion Questions | seanmccoy | Pro Tools HDX & HD Native Systems (Win) | 3 | 02-10-2017 09:16 AM |
HD io & Omni Interface Questions | noah330 | Pro Tools 12 | 19 | 06-28-2016 10:36 AM |
couple of questions about Omni hookup | musicmixer04 | Pro Tools HDX & HD Native Systems (Mac) | 7 | 02-28-2015 07:35 PM |
2 questions ...Hd omni question, native, imac | doyoung123 | Pro Tools HDX & HD Native Systems (Mac) | 8 | 06-12-2011 05:31 PM |
