AAE 6101 error
Lately, I´m getting CPU overload message errors AAE 6160 when I am recording, with no plugins inserted.
I didn´t change any cable or connection. What should I do??? Thanks a lot 1073Apples IMAC 2,7 GHz, Intel Core I5 12 Gb RAM OSX Mountain Lion DIGI 003 rack, 2m cable with converter to FW 800 ProTools 11.3 Recording Hard Drive: WD 1Gb, Firewire 800 with coverter cable to Thunderbolt Other HDs (storage): USB daisychained |
Re: AAE 6101 error
I would start by Deleting Pro Tools Preferences, repair permissions on the system drive using Disk Utility, reboot, and try again.
If that doesn't help, I'd continue on with general optimization and troubleshooting, also found in the link above. Does this happen on all sessions?
Studio rig - Pro Tools|HDX 2018.7 | Logic Pro X.4.2 | Avid HD I/O (8x8x8) | 6-core 3.33 Westmere w/24GB RAM | OS 10.12.3 | D-Command ES | Eleven Rack | Vienna Ensemble Pro 5 Mobile rig - Macbook Pro i7 w/16GB RAM | UA Apollo 8p | Pro Tools|HD 2018.3 | Logic Pro X.4.2 | OS 10.12.6 Last edited by Stig Eliassen; 02-03-2015 at 12:39 PM. Reason: Typo |
Re: AAE 6101 error
Yes, in happens in all sesions.
I´ll try what you suggest, thanks a lot!! |
Re: AAE 6101 error
Somewhat concerned about that Thunderbolt converter cable. Any reason to not just run it straight FW 800?
Re: AAE 6101 error
I briefly tried to run a Thunderbolt rig on a Retina screen MBPro, and I felt constantly frustrated from not having control over sleep and wake-up controls on my external drives (LaCie). It seemed like I could barely go 2 or 3 minutes of not accessing them before they would wind down; then the next time I hit play I'd either get an error, or I'd hear them whirring up and it could be a 5 second wait for them all to find their footing. And yes, I had the correct preferences checked in Energy Saver and I remember looking for all kinds of utilities to fool the drives into thinking they were being accessed. I just thought what a monumental waste of the speed promised by this form of connection.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Re: AAE 6101 error
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Re: AAE 6101 error
Do you have ANY third-party plug-ins in your Pro Tools system?
Re: AAE 6101 error
Any WD discs were black-label. They came with the LaCie enclosures. When I switched back to a 5,1 desktop, I put the same two drives in particular into the internal slots of the Mac and they don't do that. Choices were more limited as to Thunderbolt enclosures at the time, so if I switched back I'd search around more for other options. I'm just saying maybe spin-down is a factor here.
Re: AAE 6101 error
Re: AAE 6101 error
I have only one FW port, used by the digi 003. I can daisychain the HD drive using the spare digi FW port, but I read it's not a good idea
Error -6101 in PT 10 | Cutlerbri | Pro Tools 10 | 5 | 03-18-2014 02:08 PM |
Error -6101 | 6lovemusic | RTAS & TDM Plug-ins | 1 | 10-19-2013 08:35 AM |
error 6101 | scotchflavio | macOS | 1 | 12-20-2012 01:09 PM |
PT 10.2 6101 error. NEED HELP! | Stijn Cole | macOS | 0 | 07-01-2012 02:27 AM |
PT 10.2 6101 error. NEED HELP! | Stijn Cole | macOS | 0 | 07-01-2012 02:26 AM |
