Old 05-14-2015, 06:24 PM
Norrie's Avatar
Norrie Norrie is offline
Default
There is a Shift bottom left and Bottom right. Multi shift is also on the bottom left.
In this instance why has Marco to hold down multi shift ?
I don't suffer from insanity -- I enjoy every minute of it !
Avid S3
Artist Transport
Pro Tools HD 12
UAD Apollo 8P
Audient ASP 880
Mac Pro TrashCan
3.5 GHz 6-Core Intel Xeon E5, 32GB ram
Adams A77x
UAD Quad Thunderbolt Satellite
Old 05-14-2015, 08:23 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default
The shift buttons are not like keyboard shifts. They select the second layer of all of the S3 buttons.
The multi select/SHIFT is the same as the shift button in a keyboard.
To select multiple solo buttons, you would either use the shift button on a keyboard or the multi select/SHIFT button
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 05-14-2015, 08:40 PM
Norrie's Avatar
Default
I understand that but I took it that Marco was working with the shift layer active ?
There is also no need to multi select shift when soloing. Just hit all the solo buttons you want ?
Avid S3
Artist Transport
Pro Tools HD 12
UAD Apollo 8P
Audient ASP 880
Mac Pro TrashCan
Adams A77x
Old 05-15-2015, 03:41 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
Default
I Cliffy, I know that, but as I have the shift pressed (layer), because I need it my first workflow attempt, I discover that the solo don't work when it's pressed.
thanks anyway for the reminder, it's a good one. the name is the same but the function in this hardware is other :)
Cheers,
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
Old 05-15-2015, 07:15 AM
J-S-Q J-S-Q is offline
Default
Originally Posted by ronnievanoverveld View Post
I don't have this problem. Only want to add that I think it's strange that the solo buttons don't work when the shift button is lit.. There's no shift function for the solo knobs, so why blocking it?
If you have Shift engaged, when you press the first solo button, it stops the motorised faders from moving (but automation is still active in the session) although personally, I'd prefer it if the Solo function just acted as normal when shift is enabled.
Old 05-17-2015, 12:29 AM
ronnievanoverveld ronnievanoverveld is offline
Default
Thanks! I didn't know it (S3 is just a week here, so there's enough to find out )
Ronnie van Overveld - Sounddesigner - The Netherlands
Mac Pro Trashcan OSX Mojave, ProTools 2021.3.1 Ultimate, Focusrite Red4pre, Avid S3, Avid PT DOCK, AJA IO XT
Old 07-25-2015, 08:26 AM
Default Re: S3 Eucon 3.2.2 - SOLO bug
Bad news from here,
S3 as few faders "broken" they are dead.
Send it back to repair...
Marco Bernardo
Old 07-25-2015, 09:35 AM
Norrie's Avatar
You done all the fader test's in Vegas etc ?
Avid S3
Artist Transport
Pro Tools HD 12
UAD Apollo 8P
Audient ASP 880
Mac Pro TrashCan
Adams A77x
Old 07-25-2015, 09:37 AM
Yes, I've done all troubleshooting with Avid Support and Avid rep.
Marco Bernardo
Can't Solo Tracks When Bussed To Aux Sends / Solo Safe is armed (Greyed Out) adrianrobison macOS 5 11-19-2014 05:09 PM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Solo-Yellow, Solo Clear-Green Imagine ICON & C|24 1 05-14-2011 04:55 AM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
