Send windows disappear when clicking on edit window
Since the latest version of PT Control I have this issue.
It doesn't necessarily happen all the time. It used to be that a send window would stay open until I closed it myself, but now sometimes if I click in the Edit window the send will close itself. Particularly annoying when using bus interrogation etc, you have to go back and find the track and the send that you had open before you showed only the tracks with that send. Is there a way to switch off this behaviour?
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
Re: Send windows disappear when clicking on edit window
uncheck "Close Windows on Workstation When Exiting" in EuControl
It does seem that should be tied to the option above ("Open Windows on Workstation When Editing" choice) vs being global but for now it is all or nothing.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
For instance, I manually open sends when I want them, but changing to another track will kill the send window.
Thanks BScout, Eddie.
unchecking "Close Windows on Workstation When Exiting" seems to have solved it. Been working fine all day today. I have the drop-down set to plugins only. There are quite a few options in this new release to get your head around & not massively clear which ones cause the surface to follow PT or PT to follow the surface. I seem to have hit a sweet spot now though.
New Bug 2018? Edit window jump to vcas when clicking on plugins | JuelzB | Pro Tools 2018 | 3 | 01-19-2020 09:49 AM |
Bug? - Clicking in edit window selects everything | cheeseandpepper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-17-2012 05:11 AM |
BUG: All Clips in Edit Window Disappear! | conleec | Pro Tools 10 | 3 | 01-17-2012 10:13 AM |
Playback interrupts when clicking on edit window. | pcmusicpro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-04-2009 10:15 AM |
Clicking in Edit window does not move playback marker...help! | Lofty11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-28-2009 09:01 PM |
