BUG 11.2.2 PT messes up channel order when spotting from soundminer
Beware:
AVID changed something in PT11.2.2 so that your channel order gets messed up when spotting multi-channel files (LCR, QUAD, 5.0, 5.1 etc.) to 11.2.2 from soundminer in interleaved mode. It works fine when SM is set to split mono. Seems like AVID has changed something in 11.2.2 without notice. In case you stumble over it, turn off interleaved in SM prefs or go back to 11.2.1. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: BUG 11.2.2 PT messes up channel order when spotting from soundminer
Thanks for the heads up, what version of SM are you using?
v4.5pro a141
I think you have to change the channel layout in the "get info" (in soundminer) window of the file. Try this.
Thanks for the tip but I'm definitely not going to change the channel-layout of ten thousands of LCR, 4.0, 5.0 and 5.1 files to weird ones because of 11.2.2.
I'll spot as split for the time being. Works fine.
Pro Tools 5.1 export channel order | Charles Deenen | Post - Surround - Video | 27 | 06-08-2016 06:58 AM |
CAF channel-order still wrong in 9.0.5 | Arno Peeters | Post - Surround - Video | 3 | 07-26-2015 07:55 AM |
Locked Channel order in Bus | bcslaam | Pro Tools 11 | 3 | 08-29-2013 12:11 PM |
D-Control channel mute/solo order | JonesH | ICON & C|24 | 2 | 04-30-2009 06:26 AM |
Can you change the default channel order of an interleaved.. | dj_grimmace | Post - Surround - Video | 4 | 11-12-2007 08:10 AM |
