Cant uninstall AVID HD Driver(x64)
Hello all, Pro tools 11 user on Windows 7 here. I had some issues with PT 11.2, so I wanted to roll back to 11.3.1. I performed the uninstall of PT 11.2 (but stupidly did NOT select to remove the HD Driver, preferences, etc.), ran a registry cleaner, re-booted, and installed 11.3.1. Upon trying to launch 11.1.3, I was greeted with the error message:
"Protools 11 could not be loaded. Please contact the software publisher for support using this software. Error details: Could not find imported function in specified DLL." Anyway, I did some research and it seems the thing to do is obviously do a FULL removal , also removing all PACE stuff, do a registry cleaner, and then re-install everything. The problem im facing is that Avid HD Driver (x64) will NOT uninstall. Ive tried doing it from the device manager -> remove a program area. It gives me an error message during the uninstall, and then refuses to uninstall it. Until I can get this out of the way, I can't really do a fresh install. Any and all help would be greatly appreciated.
It's in the Mix |
Re: Cant uninstall AVID HD Driver(x64)
You MUST also remove the HD driver in ALL cases. And, its recommended to remove Pace 64 bit support as well(when you start the installer, Pace will reinstall as part of the process). Sorry I don't know how to remove the HD driver by itself(when this happened to me, I restored the system drive from an image, then ran the uninstall again so I could include the HD driver). I wish it was NOT an option(anyone at Avid listening???)
There is an HDx64 entry in Windows>Control Panel>Programs. Can you un-install from there or do you get same error message?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
There was an error message when trying to uninstall that way.
I fixed it by installing PT 10.3.8 again, uninstalling PT 11.1.3, and then uninstalling PT 10.3.8. The 10.3.8 uninstaller removed the HD Driver even though the 11.1.3 uninstaller wouldnt. Hope this helps someone out who may be in the same situation.
It's in the Mix |
Uninstall 002 Driver 10.3.3? | DEastman | macOS | 0 | 01-10-2014 04:53 PM |
Need to uninstall M Box Pro driver | ccooper | macOS | 3 | 05-20-2012 04:43 PM |
Need to uninstall M Box Pro driver | ccooper | macOS | 2 | 03-24-2012 11:19 AM |
How to uninstall HD Driver? | diamondschwin | macOS | 1 | 06-14-2011 09:48 AM |
cant uninstall mbox2 driver | myfinn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-27-2010 01:58 AM |
