HELP Mix|24 v6.4.1 just stopped working
I haven't used it for a couple of weeks, and now it just hangs when it gets to loading plugins...
I've got cs4, up to date ilok drivers, nothing new installed, I've tried removing protools and re-installing it again..... I don't understand. I didn't do anything!!! Any ideas? |
Re: HELP Mix|24 v6.4.1 just stopped working
- Reinstalling Protools sometimes does not clear it all out, particularly the steps for
" - Delete DAE and Pro Tools preference files " This, and several other good troubleshooting tips are at: http://duc.digidesign.com/showflat.p...fpart=1#802377 Another thing to test is to remove the plugins from the plugin folder, and re-install them after running sucessfully (perhaps one at a time, to find the troublemaker - or maybe there's a corrupted file, and they'll all work fine once reinstalled). Be sure to back up stuff before experimenting, and uninstall any plugin 'counts' for any plugin whose protection requires that.
steve Your Heaven |
Hello, to use protools 6.4.1cs4 on pc, you must use windows sp1. To use sp2 you must install a protools 6.9TDM and desinstall it and reinstall 6.4.1cs4. Your protools should start. On sp1 no problem.
Actually it's been running fine with SP2 for a year since I rebuilt the PC and before that.
I think I may have corrupt registry or something. I uninstalled Waves plugins and can't reinstall them becuase the installer hangs when it gets to the Registering plugins stage.... I'm going to try repairing windows..... |
It is true that protools works fine on sp2 but i have a lot of trouble with news plugins. Often i have a blue screen of death with sp2, so the only way i find to have a stable version is to install a recent
tdm version even if not written for mix+. I have a hd, so i install a 6.9 certainly install some recent programms in sp2 and my plugins works fine now. Never blue screen of death after that. Strange way but it is ok for me. |
So I've tried going back to the last windows restore point.
Re-installed Protools. Still the same problem So one by one I uninstalled every plug-in that caused Protools to hang: Waves Gold + Reaniassance TDM Sony EQ, Inflator & TransMod Mach5 Bomb Factory BF-3A MCDSP Chrome Tone & Compressor Bank Synchronic DINR Smack LE Virus Indigo URS A10 & N12 AutoTune And then it worked. I still have the follwing plugins installed and these load Ok Amplitube Bomb Factory - LA-2A, Pultec Bundle, Fairchild Bundle & the free ones Brass Dynamics III EQ III Reverb One Izotope Ozone & Trash focusrite d2/d3 Line6 AmpFarm and EchoFarm Master X3 SoundBlender & TimeBlender I've tried re-installing a selection of plugins but each of those I've removed causes Protools to hang if i re-install. All I can think is that all of these plugins are trying to access something that is missing like a dll or something.... These were all working two weeks ago the last time I used protools. I really don't want to rebuild the PC, I just want to play music.... |
My PT rig just stopped working.. | JCDC | Pro Tools HDX & HD Native Systems (Mac) | 4 | 01-01-2013 06:02 AM |
PT 8 stopped working | stereodesign | Pro Tools M-Powered (Win) | 0 | 01-11-2009 12:25 PM |
my 192 just stopped working what do i do!?!?!? | carl_laruso | Pro Tools TDM Systems (Mac) | 4 | 09-02-2008 03:55 AM |
002 and why it just stopped working? | Susie Cue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-13-2008 07:44 PM |
Just Stopped Working | macr0w | ProControl, Control|24, Command|8 | 0 | 12-11-2007 05:39 PM |
