Anyone know how to trash PT preferences on Windows XP? HEEEELLP!
Been trying to do the pref trash fix to fix a freezing prob, only help i've is a video showing how to do it with Windows 7, no help, trying to find the AppDATA folder on XP is the mystery!!! Thanks in advance!!!! BTW it's PT 8.0.3 LE
Re: Anyone know how to trash PT preferences on Windows XP? HEEEELLP!
Though the video shows Win7, the folders reside in relativity, the same place on XP;
Go to Control Panel>Folders>View Tab and select radio button for 'Show Hidden Files' You should now be able to see AppData folder C:/Users/the login name where PT is installed to/AppData/Roaming/Digidesign
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Delete Digidesign Databases and Preferences To delete Digidesign Database folders for all hard drives in Windows XP:
To delete Pro Tools preference files in Windows XP:
Aaron Mulqueen - 001 HD Native |
Well, finally figured out the trashing (thnx ZH and DUC)
but NOW all I'm getting when I try to launch PT is "the application failed to initialize properly 0xc0000005" which I've been trying to remove, did the "data execution prevention" opt out with selecting PT to not be affected, still nothing but the message |
Try setting Windows DEP back and dismiss that optimization.
Thanx Filo, it's been quite a while since I used XP.
Me too, red, I had to double check.
Thanx both filo and zed...I did try setting the DEP back and still nothing...now wondering if I should try to uninstall then reinstall PT...would that help? Would all my sessions still be kept? They are all saved on my internal music drive (the E drive) but no back ups...
I know I'm an idiot for A. not using an external drive, and B. not backing up copies. In fact I think the main drive is just partitioned though both sides are pretty huge...weirdest thing is everything was fine up til the other day, the only other issue was if I had sessions with tons of plug ins and/or virtual instruments in Expand...those session would sometime get stuck in a glitch sound or crash towards the end of a bounce to disk...almost wondering if one of those was the cause, I had just had one of them open a few days before the crash...ok...awaiting any more info. and if the reinstall might help and if my sessions are safe...thanks y'all! |
Wondering now if I needed to actually empty the trash bin after having trashed the preferences?...both digi folders are still in the trash, as well as copies on the desk top...
been spending the last 12 hours trying to de bug the 0xc0000005 issue...arrggh |
Do a search for Trasher - it's a third party utility to Trash Preferences and Databases and works very, very well. Just use the correct one for your OS.
No matter how you Trash Preferences and Databases, you should empty the Recycle Bin and then reboot your computer before relaunching Pro Tools. At this point in time having a backup plan, like Acronis True Image Home, and being able to go back to a known working system should be starting to look appealing. Given the issues you're having a complete uninstall and reinstall of Pro Tools may be in order. You mentioned the "main drive is just partitioned..." Pro Tools requires a separate physical hard drive to record your sessions to, not a partition of the System Drive. AAMOF, recording to a partition of the System Drive is usually worse than recording to the System Drive, although neither are recommended or supported. Cheers,
How do I trash Pro Tools Preferences in Windows 7? | cdvh5150 | Windows | 4 | 11-21-2012 04:29 PM |
Trash Preferences | March314 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-21-2006 04:50 PM |
Why trash preferences and what | J-P-78 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-06-2004 05:17 AM |
Cant trash preferences for 6.0...help please.. | cerebus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-30-2003 12:13 AM |
I have to trash my preferences for the first time. Anything to look out for? | Son of David | General Discussion | 1 | 06-06-2003 05:00 PM |
