Old 11-15-2017, 04:51 AM
hooksound hooksound is offline
Default AIR Frequency Shifter corrupts sessions
I'm sometimes using AIR Frequency Shifter to kind of fatten kickdrums in Pro Tools 10. Sometimes sessions are getting corrupt and won't open when AIR Frequency Shifter is present on a track in the session. After inserting AIR Frequency Shifter, the session opens fine 4-5 times in a row and then it suddenly gets corrupt and the session won't open or PT10 crashes.
I have tried reinstallation of both PT10 and stock plugs and I have tried wiping preferences.
I'm on Windows 7.
Pro Tools 10.3.10, Cubase Artist 7.5.40, Allen & Heath Qu-16, Focusrite Scarlett 18i8 2G, Fujitsu Lifebook AH532, Intel Core i7-3612QM, 8 GB RAM, Windows 7 Professional SP1 64 bit
Old 11-15-2017, 06:28 PM
unkJE's Avatar
unkJE unkJE is offline
Default Re: AIR Frequency Shifter corrupts sessions
Originally Posted by hooksound View Post
.... I have tried reinstallation of both PT10 and stock plugs and I have tried wiping preferences. I'm on Windows 7.
Just to clarify, by "stock plugs", do you mean you also re-installed Avid Effects 10.3.10?
Old 11-15-2017, 11:35 PM
Yes, all three installers, just like on your nice screen dump.
Old 11-16-2017, 03:22 AM
unkJE's Avatar
When you left-click on either of the words 'FREQUENCY SHIFTER' at the bottom of the plug-in, does it read AIR Frequency Shifter V1.0.2.10105?
Old 11-16-2017, 03:40 AM
unkJE's Avatar
2nd question:
Even though it's not listed in your Signature, have you also co-installed Pro Tools 12?
Old 11-16-2017, 04:55 AM
unkJE's Avatar
I noticed fellow Member Bunglespice had the same problem - and solved it with a "full uninstall and reinstall of PT10"
PT 10 freeze with AirFrequencyShifter
http://duc.avid.com/showpost.php?p=2380668&postcount=7
Originally Posted by Bunglespice View Post
I did a full uninstall and reinstall of PT10, but not the effects bundle, I'll give that a shot and report back in two weeks.
http://duc.avid.com/showpost.php?p=2380676&postcount=8
Actually I'll report back now. Worked great, you're awesome. I appreciate you taking the time to help.
If you're going to try a "full uninstall" - Trasher 10's the go (if you haven't already got it!)
Trasher 10
http://duc.avid.com/showthread.php?t=316863
http://www.pro-tools-pc.us/category-s/1514.htm
Builds:
Trasher 12b3: (Build 3, updated 6-26-17)
Supports Pro Tools:
10.3.5-10.3.10
11 (all)
12 (12.0-12.8 current release)
Old 11-17-2017, 11:56 AM
Yes, that's the one. And yes, PT12.5.0 is co-installed on the computer.
Let me also thank you for all the suggestions and links.
In the meantime I have found out that I can insert or remove FS, save and load the session multiple times as long as I don't close PT10 itself. After a PT10 start and reload of the session (with FS), PT10 crashes during session load.
Old 11-18-2017, 08:13 AM
unkJE's Avatar
.... I can insert or remove FS, save and load the session multiple times as long as I don't close PT10 itself. After a PT10 start and reload of the session (with FS), PT10 crashes during session load.
Does this mean, as a workaround, if you remove FS before closing session, then PT10 will load without crashing?
Do you know if this problem existed before you co-installed PT12?
Frequency shifter not working msuk Pro Tools 12 3 10-07-2015 01:06 AM
Pro Tools Corrupts My Recordings EricMulhern macOS 11 03-06-2012 06:20 PM
PT9 working poorly with UAD2, plus it corrupts sessions AND my other DAW geetarpicker Pro Tools 9 5 11-28-2010 08:49 PM
EZquest won't mount & dir. corrupts! (OSX 10.3.9) crispuk Storage Subsystems 0 07-27-2005 12:55 PM
System 9.1 & 9.2.2 corrupts digisetup jeff@hotsound Pro Tools TDM Systems (Mac) 3 11-26-2003 10:20 AM
