Izotope direct connect question
When using RX's direct connection with PT I have a question/problem. When inside RX and processing, say, clicks and I select the 'clicks only' option to only hear them and hit the audition button in the declick module I seem to hear everything. Do I have to mute the PT track when doing this?
I've tried different settings in the declick module thinking I might be taking too much out but that's not it either. Happens not only in declick but other modules as well. I know I'm in for a learning curve. Direct connect seems to be a good way to go but if I have to work in standalone so be it. |
Re: Izotope direct connect question
How do you have the RX Monitor plug in situated in your PT session? It should be inserted on an Aux track which is solo safed.
This always works for me. You transfer the clip from PT to RX standalone via RX Connect AS, then use RX Monitor on an aux in PT to monitor the result.
Question for those who use multiple daws - does Direct Connect work in anything other than just PT? |
https://www.izotope.com/en/support/k...x-monitor.html |
Rx Connect.... AAX, AU, VST
As long as you installed those options. https://www.izotope.com/en/support/k...nnect-faq.html Digital Performer is one of the Hosts that use RX as an external editor. workflow is here.... https://www.izotope.com/en/support/k...performer.html |
I haven't encountered the issue you describe above using this approach.
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
edit for additional: See this: https://www.izotope.com/en/support/k...x-monitor.html |
Izotope RX 5 Connect – 2 channels max at a time?? | reichman | Post - Surround - Video | 2 | 09-03-2016 08:45 AM |
2 Part Question: Direct Connect / Focusrite d2 | Producers Never Sleep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-26-2002 10:55 PM |
Question about Direct Connect support?!?!?! (re-titled) | crs117 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-07-2002 04:23 PM |
how-to Direct Connect | peteri | Pro Tools TDM Systems (Mac) | 10 | 05-07-2002 12:11 AM |
B4 Direct connect question | Brickdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-23-2001 12:22 AM |
