I'd like to start using reference tracks to compare against the session I am mixing, and I'm looking for advice about how other people do this in Pro Tools 11.
My initial thought is to import the reference material into my session and mute it until I want to compare. Then I'd solo and un-mute the reference material. That seems fairly straightforward but I suspect there may be more elegant solutions or workflow. What other things should I consider, from a technique or approach perspective to get the most from this practice? Thanks! |
You probably don't want to just listen to the reference vs your mix in your studio. Compare your mix to the reference in other places...your home stereo, your car, your iPod, etc. Assuming the reference mix is top notch, the closer your mix comes to the reference in places beyond your studio, the better.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC Dell XPS 435T/9000 Win-10 Pro 24gig RAM IntelCore i7 CPU 920@2.67GHz Pro Tools 2019.10 Focusrite Scarlett 8i6 |
Besides the good advice above - in PT11 - Magic A/B
Ridiculously useful ![]() http://www.samplemagic.com/details/184/magic-ab
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
Don't forget that references from released material have been mastered and often highly compressed. You have to adjust the RMS level of the reference to the RMS of the work in progress (not the peak!). Otherwise the reference will always sound better due to the loudness bias.
DC-Choppah's Project Studio: ASUS P5Q Pro Turbo /Intel Pro 2 Quad Core-rackmount PC Windows 7 professional 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle M-AUDIO FastTrack ULTRA 8R Interface Roland RD-300 / Novation XiO Keyboards Mackie 12 channel Analog Mixer Adam A8X monitors Estonia Parlor Grand Piano Yamaha Studio Drum kit https://soundcloud.com/dc-choppah |
Jurld, according to your signature, you have an Mbox Pro. That means you have Spidf digital inputs. To save yourself having to import the track of every reference song into the session, you can just use a simple CD player with digital out.
You don't need to buy a fancy rackmount one. You can just use any consumer DVD player, even the cheap $20-30 ones from Walmart. They all have digital outs and they all play CD's. Just get a digital cable, hook it up to the Mbox digital ins. Then in your Protools session, simply create a stereo aux track, and set the inputs of that track to match the Spidf inputs. Now the CD's will play right in your session. No need to record arm tracks or anything else. Another nice thing about the DVD players is that they all come with a remote control as well. If you're not using CD's, but instead want to use Itunes on your computer, you can do the same thing, assuming your computer's sound card has a digital out (Macs have this automatically, for Windows, you may need to get one). You would hook it up the same way. Note that you can use any audio source into the analog inputs of your interface as well, but it's going to be more accurate by keeping things digital. That way both the reference CD (or whatever) as well as your own mix, are both going through the same Digital to Analog converters of your interface. |
![]() Quote:
Great way spidif
Thanks for all the tips, particularly the one about just playing the CD using the spdif. I think I've got a cheap player in a closet somewhere.
I saw a reference to Magic A/B elsewhere, it looks very useful. I have been comparing my work to reference recordings in other places already. It would be great if there was an easy way to do quick a/b type comparisons in my truck on the way to work. I don't see a practical way to do that. As far as getting RMS levels of a commercially mastered recording to match my mixing level, is there an objective way to do this? Or do I just turn down the fader on the reference until it sounds "close enough". |
Insert a metering plugin that shows RMS, it should match on both tracks. You can do this without listening too. Or if you have PT11HD, you can change the mixer meters to your liking
![]() Quote:
![]() After years of doing it several ways I decided to try Magic AB and guess what? It´s so cool, so easy, just brilliant. Doesn´t alter your sound at all, so you can leave it on your Masterbus from the beginning, you super easily can adjust the volume of the reference section and comparing is a pleasure as it only needs 1 push to the reference track, 1 push back. You can choose any point of the reference track to start from and you can load up to 9 several reference tracks into the plug-in to choose from. It´s a really great piece of software which is insanely affordable for the amount it makes your life easier ![]() Highly recommended stuff IMO. Best of success everybody. P.S. if you insert an analyzer and a metering plug-in after the Magic AB plug-in on the Masterbus you additionally can compare easily your work visually to the reference tracks. P.S.2 what Magic AB makes really useful is that you can load WAVE and AIFF (up to 24bit/96KHz) files, not only MP3s (you can use MP3s too but that´s definitely not recommended actually). Comes as AAX 64bit/32bit, RTAS, AU, VST from Mac OS Leopard 10.5. upwards to Mavericks and also for Windows, from XP upwards to W8. http://www.samplemagic.com/details/184/magic-ab MacMini i7Quad, 16GB Ram, MBP Mid 2012 2,5GHz i5, 16GB Ram, MacOS 10.9.3, Apogee Quartet+Duet 2, Genelec Active, Yamaha NS10, Pro Tools 11.1.3, Logic 10.0.7, Waves, MCDSP, Duende Native, Softube, HOFA, IK Multimedia etc |
Wow, I had never heard of this pluggin! Seems amazing, I've been closing PT's then listening to iTunes, then opening PT's back up like a sucker!
I guess the biggest problem is when the vast majority of your reference material is AAC or Mp3's. Damn you iTunes, damn you!
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
compare mac and pc | raga2000 | Pro Tools TDM Systems (Win) | 19 | 05-07-2011 11:26 AM |
compare W7 to OS X | daslicht | Pro Tools 9 | 16 | 01-10-2011 02:26 PM |
MAC & 002/003 Compare HELP | Porky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-22-2007 12:25 PM |
001 and 002 compare | zero8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-02-2003 11:11 PM |
How does C24 compare to PC? | Hardnox | ProControl, Control|24, Command|8 | 14 | 03-15-2001 05:13 PM |
