Old 09-26-2012, 11:01 PM
Themystro1 Themystro1 is offline
Default TL Space on PT10, OSX 10.7 IR install Problem
I just upgraded to PT10 and needed to use TL Space for a small project and bought the digital download. Just downloaded all of the IRs from the digi website.
I have searched for the last 4 hours on how to get these IRs to install...
I go to the "Install TL Space IR Package" and go to the spot were I downloaded (downloads) on my Mac HD. I keep getting the message "One or More Files not written. Please check log for errors."
Here is everything I have done:
1) Cannot find the log, I go to the installed TLS Packages, just says installation failed.
2) Tried different drive to install from
3) Tried installing from /libraries/app..support/TL Space
4) Tried running disc permissions
5) Re-downloaded and tried
6) Opened up a new protools session, tried from track and from audio suite.
I have a feeling it is a permission problem where it cannot write to the drive. I am shocked that I cannot find any info on the DUC or any other site
I have installed TL_Space_10_2_1_Installer_77517.dmg
System specs: Mac 5,1 w/ HD Native w/omni 10.2.0 on 10.7.0
Can someone please tell me what is going on here? Feel gipped off the money and time I've wasted on this....
Old 09-27-2012, 02:57 AM
gali_kz0 gali_kz0 is offline
Default Re: TL Space on PT10, OSX 10.7 IR install Problem
I had the same problem.
Don't exactly remember how I fixed it but look for this :
- Does the "/libraries/app..support/TL Space" exist?
If not, create it. Otherwise, check the permission (must be set writable for the user you're logged in to use ProTools).
Hope it makes sense.
Old 09-27-2012, 09:53 AM
25ghosts 25ghosts is offline
1) The IRs included with TL Space sucks. So no need to install them. Look on the web. Plenty of great ones there.
2) Try inserting TL Space and open the right-side IR Browser, from the EDIT Menu choose Install TL Space IR Package and follow instructions/choose path
3) Sign into OS X as root user and install from there (Please google on how to do this) That will grant you permissions to everything
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 09-27-2012, 11:57 AM
Thanks for the advice, but none of this worked.
Here are locations I tried making folders (and setting permissions):
1) /library/app..support/digidesign/Plug-in Settings/TL Space
2) /library/app..support/TL Space
3) /users/[me]/library/app..support/TL Space
I have made myself Root user and logged in.
I have reinstalled TL Space, yet again (and yes I restarted the computer)
I am at a complete loss here - I can't even find the "LOG" file this is supposed to be making.
Can someone please let me know where the heck these install to - the full path for OSX Lion? And perhaps where this LOG file might be?
Thanks.
Old 09-27-2012, 01:10 PM
Thanks.
Look - Take it EASY ;-) It DOES work --- Just tried it extra'ly' for you !
1) Open TL Space in Protools
2) In the IR Browser EDIT Menu select "Download TL Space IR Package"; This will take you to the IR Download page of
http://www.avid.com/US/products/TL-S...sponse-Library
3) Download the IRs you want.... and LEAVE them in the download location
4) Wait for downloads to complete
5) Open TL Space, in the IR Browser EDIT Menu select "Install TL Space IR Package"; Navigate to ONE of the downloaded .tls files
and click OK.. This will open a dialog in TL Space... Repeat above step for EACH package. TL wont allow you to select multiples.
That is it... Now you are done and you can throw the downloaded files into the trash...
The IRs of TL Space are being installed into the following location: MacHD/Library/Application Support/ Trillium Lane/TL Space/impulse Responses
Hope this helps... And in the future it helps READING the F++++ manual. It is ALL in there
Old 09-27-2012, 02:22 PM
25ghosts,
Thanks, but dude - seriously you think I didn't read the manual and then post all of this? The first thing I did was read the manual then spend 4 hours poking through my system to find the LOG files....
So just for kicks - I did your instructions which again, does not work on my system.
I do appreciate the folder location, is this for Lion? - because this folder structure was not created when I installed. I made this folder structure myself and reinstalled, and then tried the download/install thing and again, did not work.
Can someone please tell me were this log file is? It's not in the standard log file location...
I think I need my money back if this is really not working with Lion and PT10.
Old 09-27-2012, 03:06 PM
Ok.... Sorry for jumping to conclusions..
I was able to recreate the install failure...
It IS a permissions problem...
I set the Trillium Lane folder and contents to READ ONLY and got THAT exact error... Your LOG file will typically (AVID Logs) be located on your MacHD top level. But it just mentions a failure...
Try this :
Go to MacHD/Application support and select the Trillium Lane folder.
Then hit Command+I and the Finder Info Window opens.
Click the little yellow Lock icon and enter your password.... In Sharing and Permissions make sure it is set to
YOU(User) READ/WRITE
admin READ/WRITE
everyone READ/WRITE
and now hit the cog wheel and from the dropdown choose "Apply to Enclosed Items"
This will propagate the permissions to all the folder inside...
Try installing now... And let me know what happens
Old 09-27-2012, 03:27 PM
Thank you! That finally worked, I forgot to change the permissions after I created the trillium lane folder. I had done that to application support last night - thinking it would have done it to this folder as well....
Thanks again!
-Sam
Old 09-27-2012, 03:33 PM
Thanks again!
-Sam
You are welcome. Glad it worked. I HATE being in situations such as yourself ;-)
Unless you use the "Apply to Enclosed Folders" OS X will not propagate the permissions.
Permissions CAN be a real pain in the neck ;-)
Old 12-30-2014, 09:43 AM
douglas42 douglas42 is offline
Hi there,
2 years later, this is still an issue
i had the same problems described above, the trick of "25ghosts" worked for me.
as an update anyway, on my system it was in a different location. it was in: machd/users/forallusers/avid/space
after changing the rights and applying to all folders, it finally worked.
drived me nuts, so thank you "25ghosts" for your help!
TL Space IR install problem Superclock RTAS & TDM Plug-ins 3 02-09-2014 03:28 PM
PT10.3.7 Install Problem chrissputnik Pro Tools 10 0 10-30-2013 06:38 PM
Xpand2 problem after PT10 install jrichview Windows 2 03-10-2012 06:44 PM
OT: TL Space-Problems in PT10 HD! lownotesinc Pro Tools TDM Systems (Mac) 1 11-07-2011 11:22 PM
Install TL Space Library problem??? montez1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-23-2010 08:30 PM
