Old 07-16-2004, 09:50 AM
cdp2004 cdp2004 is offline
Default Need help Hum with the Mbox and external mixer
Need some help. When I run my Mbox straight to my powered monitors everything is fine. But when I run it to my mixer I get this hum in which I can hear the harddrive running. I've tried grounding everything possible thing. I've switched to balanced cables,trs cables. I've heard of people having this problem with the Mbox. But haven't heard a fix for it yet. I also have a M-audio sound card in my system that I keep disable.
Thanks in advance
AMD 2500 Barton
512 ram
Mator hard drives (2)
MSI
Old 07-16-2004, 10:17 AM
Captain_Pants Captain_Pants is offline
Default Re: Need help Hum with the Mbox and external mixer
What kind of mixer?
I have a noisy Behringer mixer I try to avoid using.
Ill suffer winter alone;
ten thousand miles from home...
Old 07-16-2004, 10:23 AM
If it's a Mackie.. move it away from the computer... it's not shielded.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-16-2004, 01:44 PM
I'm using a Tascam M-08. Looking at it, it's not a ground mixer. But I've never had a ground hum until I plugin in my M-box
Old 07-16-2004, 01:45 PM
I will have to try moving it and see if that will help
Old 07-16-2004, 02:37 PM
lemix's Avatar
lemix lemix is offline
cdp2004 ,
You should be powering all your audio equipment as well as your PC from the same, isolated, clean and properly grounded AC source.
A TRS balanced, quality cable to your mixer must be used. If still have "hum", try unbalanced from Mbox to balanced into the Tascam mixer.
hope this helps,
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 07-17-2004, 03:02 PM
I'm still getting the same problem. I'm wonder if I got a USB PCI card would that help
Old 07-17-2004, 03:42 PM
After weeks of trying I have found the answer to it in my system. It wasn't the MBOX, PC or Mixer. I found that my EMU keyboard I had plugin into my mixer was the cause of a ground loop. So I had to put $1.50 ground adapter on it and it worked like a charm. If I had known that I would have done it sooner. Hope that helps.
Old 07-17-2004, 04:12 PM
Jorge442 Jorge442 is offline
what΄s a ground adapter?
thanks
jorge
what a long, strange trip it΄s been
www.abacomusic.com
Old 07-17-2004, 07:15 PM
It coverts a 3 prong plugin into a 2 prong to break the ground. You can pretty much get them anywhere. I picked one up at Home Depot
Help setting up Mbox and an external mixer asiabackpacker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-23-2005 12:28 PM
external mixer and mbox littleRO General Discussion 2 07-20-2004 05:50 AM
Mbox & External Mixer BroMdo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-25-2004 04:11 PM
Mbox with an external mixer Blair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-25-2002 01:07 AM
can mbox handle an external mixer?? mattsullivan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-11-2002 01:34 AM
