Please help me end this frustration
I want to get rid of latency and stop these pops and clicks.
I have a PC, (a fast i7 Digi Duc forum build) running XP. My chain: audio into Apogee AD16X into DIGI002 (adat) and back out of the DIGI002 to Apogee Rosetta 200 (S/PDIF) for monitoring. My options: Should I get a PCIe card, like the Lynx or RME and go directly AES from the Apogee AD16X to my computer? I would have to buy Windows 7, ProTools 9, and the pcie card. A little over $1000 for all. Or, should I buy a M-Audio Profire 2626, which is only about $600, but I'm not sure about the quality. I can't afford HD Native. If I was going to spend $3000, I'd buy a HD system. My Apogee has the X-HD card, so all I'd have to have is a core PCie card to go HD, but they are bringing $3000-$4000 even used. With my goals in mind is there another way I'm not considering? I would even consider selling the Apogee pieces and Digi002, which would all bring about $2800. Please help me. |
Re: Please help me end this frustration
Hang on cowboy. Don't give up just yet. Let's break this down a bit and build it back up one step at a time. Start with just the 002 connected. Now make(or open) a session that is at 44.1K or 48K, and set your hardware buffer to 64 and test it. If everything is good(and latency is minimal) then let's continue. Next step would be to attach the AD16X to the lightpipe input on the 002. Now go to hardware setup and select Clock Source as Optical. On the AD16X, set it for 44.1K or 48K(whatever your session is set to). You cannot use the higher sample rates with the lightpipe input. Now test again. If all is good, now connect the SPDIF output of the 002 to the SPDIF input of the Rosetta. The Rosetta will need to be told to clock from incoming SPDIF, OR clock it via Wordclock with a wordclock cable from the AD16X(I don't own these devices so I'm not sure what connections you have available). The idea is that all 3 devices must be running from the same clock(which is likely why you have clicks and pops). Since the 002 has no wordclock connections, it is best to slave it to the optical feed from the AD16X. If the AD16X is the master for the 002, it must also be the master for the Rosetta.
BTW, in the hardware setup page, make sure that Optical=ADAT and RCA= SPDIF. I got my fingers crossed for ya
Don't thank me until it works!! In any case, be aware that as of 8.0.4(and in PT9) your clock source will revert to internal every time you boot the computer, so leave yourself a post-it note to reset the clock each time you open PT.
Ever since you recommended that to me a while back, I have a piece of masking tape right on my Command 8 that tells me to do that. Last night I changed the clock to "Internal" in ProTools (DIGI002R clock) and lowered the buffer to 64. I played music into a pair of audio tracks and set PT to record. No problems, Then I changed the clock back to "ADAT" (AD16X) and there were no problems either. Wow, I thought, it's doing better at buffer 64. Awesome-shorter latency and more stability! Well, that didn't last long. After a few seconds, the music that was being recorded started sounding very digitized, like a cool digital distortion that I was turning up the gain on. Then it started sounding like the system was just about to shut down. A message box popped up that said "Remove RTAS plugins or raise CPU usage limit". I had no plugins open at all and the CPU usage was set to the recommended 85%. Any ideas?
Time for a Sandra report.
WOn't know until we see the Sandra, but I'm wondering if he's having the same issue I did and just needs to change the number of processors from 8 to 4...assuming he has true quad core.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
definitely less than 8...
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
This is a Sandra from a year ago, but it's the same computer. I haven't made any changes. Thanks for the help.
SiSoftware Sandra Computer Model : Gigabyte EX58-UD5 Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.83GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte EX58-UD5 BIOS : Award (Phoenix) F7 05/11/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.43GHz (4.86GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 540MHz (1GHz) Memory Module(s) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1600C8D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : ATI Radeon HD 4350 (PS3.0, VS3.0 600MHz, 256MB DDR3 2x400MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4350 (PS3.0, VS3.0 600MHz, 256MB DDR3 2x400MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 4350 () Storage Devices WDC WD7501AALS-00J7B0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (E:) WDC WD6401AALS-00E8B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 596GB (C:) WDC WD7501AALS-00J7B0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (D:) USB Flash Memory 8GB (USB) : 7GB (H:) PLEXTOR DVDR PX-880SA (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices SYSTEM (C:) : 596GB (NTFS) @ WDC WD6401AALS-00E8B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) SESSIONS (D:) : 699GB (NTFS) @ WDC WD7501AALS-00J7B0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) SAMPLES (E:) : 699GB (NTFS) @ WDC WD7501AALS-00J7B0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Optical Drive (F:) : N/A @ PLEXTOR DVDR PX-880SA (SATA150, DVD+-RW, CD-RW, 2MB Cache) Removable Drive (H:) : 7GB (FAT32) @ USB Flash Memory 8GB (USB) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Audio Device : Hightech Information System RV730XT Audio device [Radeon HD 4670] Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Realtek RTL8168D(P)/8111D(P) PCI-E Gigabit Ethernet NIC #2 - Packet Scheduler Miniport Network Adapter : Realtek RTL8168D(P)/8111D(P) PCI-E Gigabit Ethernet NIC - Packet Scheduler Miniport Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
My rig is almost identical. My mobo is a rev. 1 and I run F11 BIOS(not sure that makes a difference). I also run an nVidia graphics card( a $37 GeForce 7300LE 256 card). Avid is now recommending nVidia graphics(but there are still plenty of ATI users out there. One thing that made a huge difference on my rig was setting RAM timings manually(the AUTO setting made for really bad performance). Are your WD drives green, blue or black series?
Thanks for the frustration | saxplaya81 | RTAS & TDM Plug-ins | 8 | 11-22-2013 11:21 AM |
Win 7/64 bit and 8.0.4 frustration...In need of help | shade of many | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 33 | 02-06-2011 12:36 AM |
Frustration | Rusty G. | Pro Tools TDM Systems (Win) | 10 | 10-30-2003 01:30 AM |
OSX Frustration!!!!!!!!!!!!!!Help!!!!!!!! | EarnestBliss | Tips & Tricks | 4 | 10-28-2003 11:24 AM |
agh! Frustration!! | pfd4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-13-2003 09:15 AM |
