Old 03-16-2010, 01:22 PM
matthewstyles matthewstyles is offline
Default 192 Input/Out Trims Help
Hello
I am fairly new to HD systems. I have 2x 192's and just setting up our new studio with the interfaces, My mixer return track inputs are slightly off balance and so i need to adjust them. I know the mixer signal is correct and I am sending a signal from a test oscillator. I am sending the signal into the 192 on the desired inputs and in calibration mode, but the trim pots seem to have no effect at all. I am missing something here? any advice would be appreciated!
Old 03-16-2010, 03:33 PM
BaileyBass BaileyBass is offline
Default Re: 192 Input/Out Trims Help
Originally Posted by matthewstyles View Post
Hello
Welcome.. Try a search for "input trims". there was a detailed thread recently about this, and many others preceding it. Good luck. sb
Old 03-17-2010, 03:04 AM
Thank-you... yes, I did search through all posts that could be relating to that, but only found one with the same problem of Input trims not responding, but no-one responded to that post...
Old 03-17-2010, 06:08 AM
Andre Knecht Andre Knecht is offline
Are you sure the correct bank of trims (A or B) is selected in your Hardware Setup?
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
duplicating trims and fades on new tracks viaspiaggia Post - Surround - Video 11 03-11-2017 09:42 AM
192 I/O Output trims: amount of amplification Mark Ziebarth Pro Tools TDM Systems (Mac) 6 01-08-2014 04:18 AM
192 I/O - Analog output trims not working? trian Pro Tools TDM Systems (Mac) 0 08-12-2009 02:46 PM
192 input trims coming back in from analog jackruston Pro Tools TDM Systems (Mac) 0 03-07-2003 01:22 AM
Problems with Output trims on the 192 I/O DigiPanzer Pro Tools TDM Systems (Mac) 1 06-19-2002 11:57 AM
