Old 01-30-2015, 12:12 PM
stevegalante stevegalante is offline
Default HD Native on AMS/Yosemite
How come my HD Native card is not visible in AudioMidiSetup on Yosemite ? I installed/updated PT11HD with all the drivers. MacPro 5,1 8Core 2.4GHz
http://www.stevegalante.com
System details :
ProTools Native card, Ultimate 2019.5, MacPro 5,1 12 Core 3.33GHz, 64Gb RAM, Mojave 10.14.4, Lynx Aurora(n), Raven MTi
Old 02-01-2015, 02:12 PM
Chief Technician's Avatar
Question Re: HD Native on AMS/Yosemite
Is this after running the OS X 10.10.2 combo update?
Old 02-01-2015, 02:15 PM
Default Re: HD Native on AMS/Yosemite
Now that I think about it, maybe yes. It appears in AMS as "unsupported device 0 in /0 out". Do you think the update is the cause ?
System details :
Old 02-02-2015, 11:35 AM
Arrow Re: HD Native on AMS/Yosemite
Could be. The HDX systems where I work are not on Yosemite, so I do not have the means to check this.
Old 02-02-2015, 11:39 AM
Do you think is there a way to go back to 10.10.1 ? I guess no, eh ?
System details :
Old 02-02-2015, 02:06 PM
What happens if you try to run the 10.10.1 combo installer on a 10.10.2 install?
Old 02-02-2015, 03:35 PM
It seems 10.10.1 is only an update (can't find a combo), maybe I could try to re-download Yosemite from Apple Store but I think that would include 10.10.2...
By the way on Mavericks (10.9.5) in AMS the HD Native appears as "PCI-HD Native" having 0 in / 0 out. Is this normal ?
System details :
Old 02-02-2015, 05:50 PM
I don't know, as I don't have access to HD Native to try it.
Old 02-08-2015, 12:16 PM
tonykitowicz tonykitowicz is offline
Have you run the test program that is installed when you install the HD Drivers?
After I ran that then all of the ins/outs were available in AMS.
The only problem is that all though everything shows up, it seems that Avid needs to update the CoreAudio driver as well as Native Instruments software will hang (not start) if that driver is present and Logic even hangs as well since it tries to access the NI audio units. The only "fix" is to remove the CoreAudio driver from the HAL folder and then of course you no longer have any access to you HD Native interface outside of Protools.
Old 02-08-2015, 07:49 PM
If you mean the Digitest yes I did, same results on both OSs...
System details :
Does this mean any app or just iTunes won't work with HD Native on Yosemite for 11.3? tonykitowicz macOS 9 05-08-2015 06:49 AM
Anyone with HD Native Thunderbolt on Yosemite? I have questions.. Spydog1985 Pro Tools HDX & HD Native Systems (Mac) 3 01-13-2015 12:27 AM
PT9 Yosemite paldry Pro Tools 9 2 12-27-2014 09:40 AM
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 09:48 AM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 08:58 AM
