S3 Display font size problem
Hello,
It was working fine till yesterday, but font size has been changed as picture. OS is 10.11.4, Eucon version 3.4.11171610. It happened same when I install Eucon 3.2 on El Capitan. After I go back to 10.9.5 and 3.2 works fine. However, after I checked that there's 3.4 which supports 10.11. Upgrade both. However, it happens again. Any idea? Thanks in advance |
Re: S3 Display font size problem
Somehow, it is normal today. I will keep posting if that happens again. Only difference is PT control isn't connected today. I will do it later today.
In the app set file there's the possibility to set the font size via a simple text editor. I did it for the soft keys pages in the PT Control app. Worked fine.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
1. In EuControl Settings, move S3 from "My Surfaces" to "All Surfaces" list 2. Drag EuControl Settings window back to your computer's primary display 3. Move S3 from "All Surfaces" back to "My Surfaces" list If you always keep EuControl Settings on your main computer's display this issue should not occur again.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Thanks,
It happened again, but after I turn on MC Transport it back to normal. I guess if there's control for font size, it will be nice. Thanks |
Do you have two monitors? That's where we've seen this issue. And if so, which monitor do you have the EuControl Settings window on?
I have 4K, 29" wide monitors. When this thing happens, I just turn off 4k and back on. I hope there's simple solution on control. thanks
Simple solution is mentioned in my first post. Is that not working?
Just wanted to add to this that I am also experiencing this bug, and Kyle's workaround fixes the issue. 10.11.3 on an Retina Macbook Pro with a secondary display vs HDMI.
I move the Eucontrol settings to my laptop's display and remove the unit and it automatically re-adds itself and is fine. Annoyingly though I have to do this everytime I load it up as I use an external monitor as my main display so the Eucontrol window defaults to this one. Be great to see this fixed in an update soon! |
EuControl 3.7.0.138 on OS 10.14.2. PT 2018.12
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1 |
Font size. | r.heyman | Pro Tools 11 | 2 | 03-01-2015 05:29 PM |
Increase Font Size | garden rock studios | Pro Tools 9 | 6 | 04-06-2011 06:38 PM |
Change font in Pfreferences display | matthewacacia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-31-2009 04:21 PM |
Increasing font size? | MboxToo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-06-2009 06:20 PM |
Increasing display font size | MboxToo | Tips & Tricks | 1 | 05-06-2009 06:17 PM |
